Old 04-01-2007, 03:36 PM
mitsu3kgt mitsu3kgt is offline
I need bolts
Do anyone know where I can get cam cap bolts?? I need some to put my engine back together.
Old 04-01-2007, 04:05 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: I need bolts
25% off factory parts!! i also have some in my garage I think
Old 04-01-2007, 05:13 PM
Re: I need bolts
How much for about 6 bolts?
Old 04-01-2007, 05:17 PM
jason_bet's Avatar
Re: I need bolts
I can look it up tomorrow.. PM me your vin
Old 04-02-2007, 04:06 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: I need bolts
keep in mind, there are 2 sizes for the cam cap bolts. the end caps have 12mm heads, and the 3 inner caps have 10mm heads. not sure if bolt diameter is different. but jason can hook you up.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
