Go Back   Automotive Forums Car Chat > Nissan > Quest | Presage | Serena
Old 04-01-2007, 10:18 AM
findyourseat findyourseat is offline
Lots of noise from overhead DVD console
My 2004 Quest has the overhead console with 2 dvd screens. I have a lot of squeaking at the very front of the console. Has anyone else had this problem? If so, has anything been done to eliminate the noise? Thanks!
Old 04-02-2007, 09:49 AM
chubbybubba1 chubbybubba1 is offline
Re: Lots of noise from overhead DVD console
That's odd. I never heard of a technical service bulliten for this. I bet you could tighten the screws and/or bolts that hold that console up, and it would go away. Also, it is under warranty I'd bet. Call your local Nissan dealer.
Old 04-03-2007, 09:22 PM
Thanks for the input. I have tightened the screws and installed felt washers on all screws. Neither item has worked. I will contact the dealer to see if they can fix it. Any other input is much appreciated. Thanks!
Old 12-21-2007, 02:59 PM
m98cox m98cox is offline
There is a TSB for this. My dealer performed the work and it is fine now. They had to drop the entire overhead unit and replace the bolts/nuts.
Old 12-21-2007, 03:41 PM
Thanks for the info. Any chance you have a TSB # for this?
Old 01-09-2008, 01:37 PM
Sure, I believe it is NTB04-127 - Rear roof console moves/shakes/squeaks and/or rattles.
