| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Car Doesn't Start In Cold. Changed Alot Of Sensors
hello.der.. well my 90 turbo talon doesn't start in da cold. compression is good i got spark, and fuel is good too. the forum said to check the coolant temp sensor. i replaced the sensor. then the forum says to change the AIR INTAKE SENSOR. i checked the sensor its working fine i put a voltmeter and checked resistance after using a hair dryer.. please help cant figure out wats wrong.
thanks |
Re: Car Doesn't Start In Cold. Changed Alot Of Sensors
changde plugs and wires and check firing order
Did you verify that the new Coolant Temp Sensor is working properly. Do you have access to a logger?
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
