Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 04-01-2007, 01:56 AM
Lorelai Lorelai is offline
timing chain
I own a 1992 mercury grand marquis. It is a beautiful car, well the other day i was driving it and the timing chain snapped. How much would it cost for a new timing chain, and could anything else be ruined on the engine when a timing chain breaks?
Old 04-02-2007, 02:05 PM
keeps on runnin keeps on runnin is offline
Re: timing chain
no expert but I am pretty sure that valves and/or pistons can be severely damaged by the loss of the timing chain. if you know a trustworthy mechanic have him check it out. also I believe there is a new and improved timing chain, at least there is for my 89. good luck, let us know
Old 04-04-2007, 09:59 PM
Re: timing chain
well, I talked to my mechanic and he said it would probably cost around $1000 for a different engine and another $500 for labor what do u guys think i should do. Would it be worth it?opcorn: It is a beautiful car, especially for it being a 1992.
Old 04-05-2007, 01:06 AM
reekor reekor is offline
Re: timing chain
It this a 92 with the overdrive lockout button on the gear shifter or do you have a D and OD on your gear selctor with manual of shift?
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 04-06-2007, 05:21 PM
Re: timing chain
my gear selector is as followed on my mercury,
P R N Overdrive D and 1
Old 04-06-2007, 06:06 PM
Re: timing chain
Okay you have an early 92 (made before 2/18/92)without electornic overdrive lockout. If you do buy another engine make sure it has a 2 bolt starter and not a 3 bolt. Mid 92 and newer engines will not fit your car even though they look the same. This is what will fit.
CROWN VICTORIA 92 (8-280, 4.6L, VIN W), 2 bolt starter (thru 2/18/92)
GRAND MARQUIS 92 (8-280, 4.6L, VIN W), 2 bolt starter (thru 2/18/92)
LINCOLN TOWN CAR 91 (8-280, 4.6L, VIN W)
LINCOLN TOWN CAR 92 (8-280, 4.6L, VIN W), 2 bolt starter (thru 10/91)
Old 04-06-2007, 10:46 PM
Re: timing chain
Thank you for the information, i really appreciate it. I never knew that there was a difference in the engines, i thought they were all the same
