Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-31-2007, 11:53 PM
Rmetkin Rmetkin is offline
Compression Problem
Hi I have a Talon TSi 1991, with a 2.0 16 valve Turbo, The problem is that on piston 2 & 3 I dont have any compression, what could be the possible causes?
I am confused since some people say that its the head gasket, others a cracked head, others say that some valves are done...
can U help? I dont want to spend more than i should.
thanks
Old 04-01-2007, 08:29 AM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Re: Compression Problem
take the heead offf and look, then take it to a machine shop.
Old 05-17-2007, 04:42 PM
gman266 gman266 is offline
put a few drops of oil in the cylinder and turn the engine over again.. if the compression dosnt go up you have bad valves if the compression dose go up you have bad rings
