Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-01-2007, 12:46 AM
whitez28 whitez28 is offline
transmission issues...
i drive an automatic 02 z28 with 28k on it. the trans is acting up though. the shift from 1st to second is rough unless i'm on the gas hard or barely at all. if i give it a normal amount of gas like starting from a light the shift is hard and jolts the car. 2nd to 3rd is a little rough to but not bad at all. the worst part is that if i'm all the way on the gas it sometimes won't upshift unless i let off a bit. it will just red line and rev... it doesn;t seem to be getting worse but i'm nervous i'm damaging it more by driving it. there is plenty of fluid in it and it was recently changed. any thoughts on what might be wrong?
Old 04-01-2007, 06:25 PM
bag91's Avatar
bag91 bag91 is offline
Re: transmission issues...
Maybe transmission mounts??
did it start right after the fluid change?
91 RS Camaro V8 305 TBI
cold/ram 14"/3" open element
K/N filter
3.73's
B&M Megashifter
180 thermostat
Flowtech TERMINATOR Exhaust
3" exhaust cutout
Silvania Silverstar Headlights
Ronal R15 Firehawk Wheels
Hankook Ventus Sport (front)
Sumitomo HTR+ (rear)
275/40ZR 17 all around...
_____________________________
Old 04-01-2007, 10:39 PM
jester151315 jester151315 is offline
honestly i would take it to a transmission specialist. I work for automatic transmission rebuilder and most of the time all places will do a free diagnosis and they will tell you what is wrong and if you should fix it, just take it in, they more then anyone on this site (no offence)
Old 04-08-2007, 11:09 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
this sounds like a stuck throttle valve. it seems to be stuck in a position that creates too much pressure at idle and not enough pressure to at wide open throttle (i.e in the middle).
three solutions....
(i'm assuming that your trans is not electronically controlled)
1)
-remove the transmission throttle valve line from the throttle body, it will be right next to the engine throttle (the part that moves when u hit the gas). they look similar.
-take that throttle valve (TV) cable and rapidly move it in and out. if you do it hard/long enough it should unstick the TV inside the trans.
2) -find an empty road
-place shifter into lowest gear (1st)
-hit the gas quickly, on and off, repeatedly. dont be afraid to go full throttle then back.
-this only works in a forward/reverse drive gear (i.e. not neutral or park) because there is no oil pressure thru trans in the non-moving gears.
3) take to tranny shop.
they will charge $300-$400 to diagnos and unstick this valve (if this is the problem, but im confident that it is).
What's the status on this??? done anything yet?
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 04-08-2007, 11:19 PM
Originally Posted by jester151315
just take it in, they [know] more then anyone on this site (no offence)
ok newbie, dont make statements like that. there are several relatively well versed transmission guys in this section, myself included. in addition, just about all shops wont tell you anything except that they need to tear it apart to find out the problem and charge lots of $$$ to do it.
sometimes the problem can be remedied by a processes that can be done in your home garage and with the help of forums members.
dont assume we dont know things.
Old 04-10-2007, 12:46 AM
ok im sorry if i insulted you, but my dad ownes a automatic transmission company that builds more transmissions in a day that you can ever look at, so im sorry if i think imay know something about them, but hey, im just saying take it to an expert, my dads guys know what their doing
Old 04-10-2007, 12:49 AM
lol and thats smart advice to just rev up your engine in 1st when you might have a broke transmisison, dont expect any load sounds comming from under your car or anything
Old 04-10-2007, 09:31 PM
I would normally be annoyed with you right now, but since I realize that you are a young idoit, I can't fault you for what you say.
first of all, you should go back a grade or two (to 2nd grade) and re-learn how to spell:
"ownes" = owns
"comming" = coming
"broke" = broken
im sure since your big Da-Da owns a company, that makes you an genius on the matter. that was great genius transmission advice you gave: "go pay a lot of money to have a shop look at it."
people come here for real help and not empty suggestions from people who know somebody that knows alot, but actually knows nothing themselves.
case in point... "load sounds". i believe you were horribly failing at an attempt to say that the engine would not be under any load while accelerating due to transmission slip... which shows more ignorance on your part because his tranny isnt slipping. it's shifting very hard, which means no slip.
do us all in this community a favor and discontinue your memebership and go back to masturbating to Spongebob Squarepants.
Old 04-10-2007, 09:45 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
er. i do believe he meant loud.
lolz. and yeah, i agree that there are people on these forums who know a lot.. and they often do have the right ideas.
helped me out lots of times in the past.. hell, thats why we come back, right?
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 04-10-2007, 10:52 PM
if he meant loud, thats even worse. the 'a' is far from the 'u' on the keyboard... hmm...maybe that should be 1st grade instead....
excuse my attitude. i just dont have any patience for people like this.
Old 04-15-2007, 09:16 AM
Blue Bowtie's Avatar
Registered Offender
Aside from not being very pleasant to new members, insults are namely prohibited in the forum posting rules. Since you are being kind and gracious, however, and "can't fault him for what he says" you probably should be afforded the same consideration.
"ownes" = owns
"comming" = coming
"broke" = broken
Faulting people for spelling and grammatical errors can be dangerous. Incidentally, I believe "young idoit" = young idiot.
Since the vehicle in question is an '02, it's very likely it has a 4L60E. You'll have a really hard time finding a throttle valve anywhere in a 4L60E. My guess is that it isn't a throttle valve problem.
Fortunately, site administrators and forum moderators do have some patience for all the types of members posting in this thread. Sometimes, the little things are just not worth fretting over.
Have a pleasant day.
Old 04-21-2007, 08:05 PM
sneaky7980 sneaky7980 is offline
I gotta chime in on the sponge bob comment. I don't know why but that just cracked me up! If anything thanks for the laugh!
but while i'm here.......i am having the same exact problem in my 99 ta with 41k. Not sure if it matters (sometimes the craziest symptoms help diagnose
the root problem) but my throttle sticks at mild pressure when initially applying the gas. Just annoying but didn't know if it could be interconnected to my shifting .
btw i'm an aircraft mechanic and whenever im presented with a problem i want to know every single "unrelated" discrepancy with the jet. sometimes it helps tremenduosly in fixing the "real" problem.
