Old 03-31-2007, 07:28 PM
DeadBlade89's Avatar
DeadBlade89 DeadBlade89 is offline
Send a message via AIM to DeadBlade89
Which One to Choose...
Ok, ive looked hard and finally found the subs that I want. I will be getting 2 Hifonics "Titan" 12" Subs. They are dual 2 OHM, and put out 400W RMS each. The thing that im stuck on is which amp should I get? I kind of want to stick w/ a Hifonics "Titan" amp. Ive looked at 3 different Hifonics "Titan" amps and idk which one will be best, if any. Heres the specs of all 3 of them...
Hifonics "Titan" 4-Channel Amplifier 680 Watts RMS
•1360 Watts Peak A/B-Class Amplifier
•4 x 170 Watts RMS @ 2-Ohms
•2 x 340 Watts RMS Bridged @ 4-Ohms
Hifonics "Titan" 2-Channel Amplifier 600 Watts RMS
•1200 Watts Peak A/B-Class Amplifier
•2 x 150 Watts RMS @ 4-Ohms
•1 x 600 Watts RMS Bridged @ 4-Ohms
Hifonics Car Audio "Titan" Mono Block Amplifier 750 Watts RMS
1500 Watts Peak A/B-Class Amplifier
•1 x 750 Watts RMS @ 1-Ohm
•1 x 500 Watts RMS @ 2-Ohms
Thanks guys for your help!
2000 Pontiac Sunfire SE
Originally Posted by freakray
You're right, I actually own a '94 Civic, I just put Subaru badges on it and make the turbo noises as I drive down the road to fool other people.
Old 03-31-2007, 09:10 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: Which One to Choose...
Are you 100% on the subs, there are better out there. But it really depends on what you are after and its better than an a-bomb.
As for subs the 4 channel amp is the best for your setup. Bridge them at 4 ohms by wiring the subs coils in series will give you 4 ohms so wire each sub in series and bridge each set of channels.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 03-31-2007, 09:43 PM
ya, im 100%. Hifonics is a pretty good brand and i like the look. i also dont want too much power to the point where i need a new altenator and/or a 2nd battery. just enough power to sound good and get away w/o replacing alot of things.
ok, thx. ill probably do it that way then and get the 4 channel.
Old 03-31-2007, 10:35 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
a dual 2 ohm sub is generally made for a single class D amp, whih are most efficient at 1 ohm. If you want 2 subs and want to maximize power output from the amp(s), you can 1) get a class D amp that is stable to 1/2 ohm and wire them both in parallel or get one that puts out acceptable power at 2 ohms and wire the 2 subs in series.
Old 03-31-2007, 11:17 PM
Or you can get the 4ohm dvc subs instead. And just wire everything in parallel. Theres alot of ways to go about it. And i will agree that a mono block d class amp would be better but i was just telling him which one out of the ones he selected would be best.
Cardomain
Old 03-31-2007, 11:33 PM
PlayStation3 PlayStation3 is offline
that and if this is your first system you might do one of two things think it is loud enough or think it is weak and you need more. and if you want more then you are going to need an efficient amp as possable.
Old 03-31-2007, 11:47 PM
ok, well is there an amp anyone can recommend me?
all useful info guys. thx
Old 04-01-2007, 01:13 AM
Your going to want about 600-800rms @1ohm. Whats your budget.
Try these brands for an idea hifonics, autotek(made by maxxsonics who makes hifonics but they actually put out closer to there rated power than hifonics). zapco, us amps, pretty much and good quality amp. Research what you want and ask opinions. Its better to get as much research as possble.
Cardomain
Old 04-01-2007, 09:39 AM
ok, ill look into all of those brands. tecnically i have a budget of $1500 but i was only looking on spending $200-$300 on an amp.
Old 04-01-2007, 03:56 PM
Audio Guy
typically, when you buy what you really want the first time - you end up spending a lot less in the long run. Look on places like ebay or for sale forums on the different car stereo or competition forums. If you can find a good quality 800-1000 watt amp for like $300-400 used, you robably won't have to end up buying another one.
Old 04-01-2007, 04:39 PM
I just found this Hifonics "Titan" amp...
Hifonics TXi 1007 Titan Series Class D 1000 Watt RMS
-350 watts RMS x 1 channels into 4 Ohms (stereo)
-700 watts RMS x 1 channels into 2 Ohms (stereo)
-900 watts RMS x 1 channel into 1 Ohm
-Class D Design
If that doesnt work, then im not going to bother w/ any Hifonics amps anymore.
Old 04-01-2007, 04:48 PM
Il bet the 900 is at 4ohms.
Look on ebay for the autotek MM1000.1d, its about 200 and does 1000rms @1 ohm.
Cardomain
Old 04-01-2007, 04:55 PM
ok...so u think I should go w/ the Autotek MM1000.1d over the Hifonics TXi 1007? how would I go along wiring the Autotek if I get it?
Old 04-01-2007, 05:07 PM
ok, i just went on a different forum about the Autotek amp. they said its good but they all recommended this one instead...
http://cgi.ebay.com/MASSIVE-AUDIO-10...QQcmdZViewItem
they said it will put out 100% power unlike Autoteks 80%. wut do you guys think?
Old 04-01-2007, 06:15 PM
Dont know what there talking about my autotek puts out almost 100% of rated power. Ive got a mm75.4 which is 250x2 bridged and i was right at 248 and some change when i was tuning it. And i have heard good things about massive.
Cardomain
