Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 03-31-2007, 05:25 PM
H23A1Lude H23A1Lude is offline
Send a message via AIM to H23A1Lude Send a message via Yahoo to H23A1Lude
Idle level is too low (94 Prelude SI)
My car doesn't start sometimes because of it. The needle rests on zero and I have no idea how to adjust it because my car doesn't have a manual. Can someone help me out on this so I can drive, because it's Texas and it's already getting hot. It didn't start today.
1994 Honda Prelude Si H23A1
Me: Get new U-Joints, then your Ford won't suck as bad.
Him: Do I need o-rings?
Me: No you idiot.
Him: Sorry, I've never replaced an O-Joint before
Me: FAIL
Old 04-15-2007, 11:46 PM
shaunsgsxr shaunsgsxr is offline
Re: Idle level is too low (94 Prelude SI)
on your throttle body on the passenger side by ur intake there is a screw that goes into the throttle body horizontally. it is a regular screw driver. turn it counter clockwise a half turn and see wat it does. if its not enough turn it another half turn
Old 04-23-2007, 09:23 PM
Ok, thanks bro, I'll let you know how it runs when it's hot out.
Me: No you idiot.
Me: FAIL
Old 04-26-2007, 11:02 PM
Dude I had that shit like almost all the way out
And it still doesn't start.
I put it back to about where it was. Any other suggestions?
Me: No you idiot.
Me: FAIL
Old 05-03-2007, 06:48 PM
Me: No you idiot.
Me: FAIL
Old 05-14-2007, 02:40 AM
O'Dailigh's Avatar
O'Dailigh O'Dailigh is offline
Up the timing.
lossen the 3 10mm bolts on the dis.
turn dis all the way twoard fire wall to up the timing.
keep the wrench with you in the car.
Test it goign down your street.
If it knocks, rotate away from firewall at 1mm segments untill there isn't any pinging or knocking.
also!!!!! try to use 90-93 octane.
Reset the throttle though.
Make sure to mark the original timing posistion on the distributor first though!
