| Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums. |
programming a key remote for a 95 cutlass
I have a 1995 olds cutlass supreme covberle I just got a new remote for the car. How do I programmed this remote for my car?
Re: programming a key remote for a 95 cutlass
1-Open trunk
2-Remove right rear trim panel 3-Taped to a harness near the antenna mast is a single pin plug going no where. Wire color in that plug is probably black/white. 4-Ground that wire. The door locks will respond by locking, then unlocking 5-Press and hold Lock and Unlock buttons simultaneously for 10 seconds 6-The doors will lock then unlock indicating the system has learned that transmitter 7-Repeat step 5 for all remaining transmitters 8-Remove ground from the program jumper 9-Verify proper remote functions. The keyless reciever appears to be mounted to the right side of the right rear speaker in the trunk seperation panel. If you must go there because you can't find the program jumper where previously described, the program wire is in pin L. It is a black/white wire at the keyless reciever.
Replacement keyless entry remotes available here - up to 90% off - All makes/models from Acura-Volvo, 1988-present - http://www.OriginalKeyless.com |
thanks its working now!
