Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 03-31-2007, 03:21 AM
nicke66 nicke66 is offline
Unhappy Pro Lock Anti Theft System
My 3.8 Trans Sport will not crank. Nothing happends when I try to run the starter. I have not yet tried to find out what is wrong, but I suspect the Anti Theft System that the dealer in Canada built into the Car when the first onwer bought it in 1995. It has not been working proberly for the last year, and a few times I have had to unplug the connector to the control box, and then plug it in to the box again to be able to start the car. I now have to remove this crap from the car. Does anyone have any experience with this Anti Theft system (Pro Lock) and can help me. There is one plug with a few wires that is going to the indicating light diode for the system, one plug with about 4-5 wires, one plug with about 10 wires, and two heavier wires (about 3 mm2) going to the control box.
Please, I need help with this! I have seach for the company that sold this system on internet, and the only thing I did find was that the company closed there business in the late 90´.
Old 03-31-2007, 06:28 AM
LMP's Avatar
LMP LMP is offline
Re: Pro Lock Anti Theft System
Indeed..all I found is this;
http://en.allexperts.com/q/Auto-Thef...anti-theft.htm
..replying same question..you had probably found it yourself.
I'll ask a few questions around....
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 04-02-2007, 06:05 AM
Yes, I did find that page, and the Anti Theft System is really simple. It is just installed in the ingition wire going from the ignition key switch.
Remoing it seams to be easy:
"Once you locate the starter wire in the ignition,
cut off the leads going to it from the prolock,
and repair."
However, this system was not the problem. The startar motor was shot. Two brushes was almost worn down to non-existent. I am surprised, because it has worked great until Friday.
