Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 03-31-2007, 02:41 AM
92pickup 92pickup is offline
Steering Damper?
i have a question on the removal of the stock damper how do you get it off the relay bar in my manual it says to use a puller to remove but no body sells it what would i do to get it off im thinking off trying a propane torche on the stud to see if that will loosen it k thanks
Old 03-31-2007, 10:54 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Steering Damper?
Depending on how it's mounted a ball joint (or similar) fork will work.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
