Old 10-11-2002, 01:48 AM
RSXGeorge RSXGeorge is offline
Question Re: Installing an H22A in a 95 GSR
I have a 95 Integra GSR and I am going to install an H22A in it. The engine came with everything exept for the ECU. I cant seem to find a decent priced ECU for this thing. Can anyone tell me which ECU will work with this thing. Wether it would be from a civic another integra or whatever. Im not sure if the ECU from my 95 GSR would have worked I wasnt able to try it since I sold it with the motor before I got the H22A. Any help would be greatly appreciated.
Thx
Old 10-11-2002, 04:08 AM
Sulsa Sulsa is offline
I hear you can use the P72 from the GSR (the ECU you had). If the engine is obd2, you need an obd2 ecu, and the same if it's obd1. And yes, they are one of the most expensive ones you can buy. E-bay is probably your best bet, if you are patient you can probably get one for about $200. I would suggest trying partstrader.com, but I've been screwed every single time I used that site. E-bay is relatively safe in comparison. Anyhow, good luck.
What needs to be done to an H22a internally to make it boost safely? preludeguy017 JDM Motor & Parts info/chat 1 06-02-2010 01:28 AM
Looking for JDM Swaps B16, H22a, GSR, Type-R quality_jdm_motors Canada 0 06-04-2004 10:55 AM
Question about installing new exhaust morbert Engine 2 09-17-2001 04:42 PM
