Old 03-30-2007, 07:26 PM
Andrewhuffman Andrewhuffman is offline
fuel pump
1995 lesabre custom 3.8SI 130K
i changed my fuel pump 6 months ago due to a problem with the car, and it didnt solve it. now that that prombe is fixed a new one occured, so i changed my fuel pump again last monday. problem gone again. last night my ball joint broke so i parked my car and when i went to crank it today, it wouldnt start. again i dont hear my fuel pump when i turn the key so its not turning on. this problem didnt occur while the car was running so i dont want to relace the fuel pump again. ive been told to check the #6 jumper, but i dont know where that is. also i never could find a fues for it. i want to know what i can check before ripping out the gas tank yet again.
GT2560r's, Nismo 615cc, ARP Head Studs, UD Pulley, SouthBend Stage5 clutch, 60mm TB's, Ash-spec Tune, Specialty Z 3" DPs, HKS intake,
Energy Suspension, z1 Drive Shaft,E-fan, Port/Polished heads, AMS Manifolds, HKS SSQV BOVs, Howe Radiator, RPS segmented LW flywheel, UR OverDrive waterpump pulley, Billion Thermo, z1 silicone hoses, Stillen gauge pod w/autometers, D&S rotors all around
Old 03-31-2007, 08:25 AM
maxwedge maxwedge is offline
A990 racer
Re: fuel pump
On the same site as the link I sent you, you will find chassis wiring diagrams that you can use to track this problem.
Old 03-31-2007, 08:28 AM
Mickey#1 Mickey#1 is offline
Re: fuel pump
Fuse #6 is under the dash on passenger side.
You may have a bad fuel pump ground.
Here's a link that will show where to find the ground. Fuel pump ground will be the connector that has black wires going to it.
http://www.bonnevilleclub.com/forum/...=article&k=102
Old 04-04-2007, 03:05 AM
89probegl2.2 89probegl2.2 is offline
Re: fuel pump
can u send me the link that u sent him please
