| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
1998 Cavalier LS headlight issue
I have changed the headlight already on this car. It still doesnt work. I traced the wires back, what I could see, and there are no shorts. Help!!!
Re: 1998 Cavalier LS headlight issue
Did you test to see if there was any power going to headlight ? Did you check the fuse?
Life Is A Highway ,Enjoy The Ride
yes, sure is. 10.7 V with car off, and between 12.6 and 13.2 with car running.
Mabe a bad wire, or two????
possibly a bad splice (corroding) in the wiring harness . you will have to follow wiring harness back from headlight . when you find a splice give it a good look and pull on it see if it comes apart. these cars are bad for headlight wiring. How`s the voltage at the battery ? it seems kind of low . Check your posts ,be sure they`re clean and tight.
Thanks, that's just what I did, and found 3 breaks in the ground wire, and 1 in the power wire. I have 2 lights again!!!!
good deal ,Thanks for posting your end results.
Does anyone know if this sort of wiring job is easy to do? By the discription of whats wrong and things that were checked, looks like i have the same issue.
