Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 03-30-2007, 01:49 PM
capriceowns capriceowns is offline
starter removal
So today I go to start my caprice(1987 305) and I turn the key forward all the lights come on the MC solenoid ticks but the starter does not turn my engine over it doesnt do anything, I tried jumping my battery cause maybe it was low same thing, I also took a long socket extension and hit it with a hammer against the soleniod nothing.
Im under my car trying to take it out, and its pretty much killing me. I got the flywheel cover off, the 2 bolts to the starter and the nut that holds the wires on. but either the exhaust pipe has to move or my trans coller lines or this stupid bar that connects to my frame and thats it, Tried looseing it but its a bolt with a nut and theres on a hole in ym frame that wrench fits into but the nut is on a angle and is next to impossible to get off.
am I doing something wrong? I figured a starter would be easy.... my chilton manual is no help, its just like "you remove the starter"
1987 Chevrolet Caprice classic Brougham. 142,000 on the 305 and still chugging
Old 03-30-2007, 01:53 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: starter removal
Loosen the exhaust pipe. That's what I had to do with mine.
Are you sure it's the starter? It could actually be the switch or something in the column!
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 03-30-2007, 02:24 PM
Re: starter removal
im pretty sure its the starter, ive had issues with it before, like it not engaing the flywheel all the way or not disengaging when i turn the key back(makes a really good grinding noise)
How can I check the column switch, i didnt know bout that.
Old 03-30-2007, 05:01 PM
CD Smalley CD Smalley is offline
Re: starter removal
That's an 18mm nut and bolt. I now have a Craftsman 18mm 1/2" socket and 18mm box-end wrench in my tool box, just so I can change the started on a b-body.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 03-31-2007, 12:18 AM
Re: starter removal
Well I managed to get the frame bar off, and the starter out. took it to autozone to test it, the solenoid was fine but the starter its self was bad. 46$ and and another 1 hour of my time to put it in and were good to go
Old 03-31-2007, 06:41 AM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
Re: starter removal
I had the same problem a few years back with these later (1977+) b bodies till I called my father-in-law, grumpy, who is a mechanic. His final answer was: bend the tranny lines out of the way. You only have to bend them slightly, have the inspection cover removed, and slide the starter back once you've removed both wires. And that works just fine. I did my 1991 the other week, no problem. If your tranny lines are rusty and break, it was time to replace them anyway. Goodyear makes rubber? transmission oil cooler hose which you can use to repair rusty sections if bending steel pipe isn't your strong suit.
BTW, you don't need to have a flaring kit and pipe bending tool to repair the steel pipe. Per grumpy, you can make connections with brass compression fittings, and to bend pipe, just get the appropriate size spring to slide over the pipe so it doesn't collapse. Actually, for larger radius bends you can carefully bend by hand using something solid like a pieve of wood as a template.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
