Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-30-2007, 12:55 PM
1982 CutlassCalais 1982 CutlassCalais is offline
Transmission Question
Has anybody ever converted an automatic trans to a stick shift Need advice. where to buy, is there a kit for that and if it is possible??????????
Old 03-30-2007, 07:43 PM
scoopy03 scoopy03 is offline
Re: Transmission Question
automatic transmission have clutch packs whereas a manual transmission has gears in it. you will need to find a manual transmission and of course a clutch+pressure plate to convert.
The key difference between a manual and an automatic transmission is that the manual transmission locks and unlocks different sets of gears to the output shaft to achieve the various gear ratios, while in an automatic transmission, the same set of gears produces all of the different gear ratios. The planetary gearset is the device that makes this possible in an automatic transmission.
99 olds alero 2.4 DD
92 notchback with 460 carb'ed
Old 03-30-2007, 08:48 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
I think he was talking about changing from an auto to a stick scoopy03......
It is possible with the 4cyl, unless you find a v6 with a stick and they are few and far between.
Thier should already be a clutch pedal braket fabed into the firewall. So you would have to swap out several things to get it to work, on a 4cyl.
And Welcome to AF 1982 CutlassCalais !
1999 Grand Am SS 3.4 OHV
Old 03-30-2007, 09:39 PM
i looked at the post a totally different way heh
Old 03-31-2007, 09:04 AM
I guess they could be asking about converting an auto trans to manual, which isnt possible
