Old 03-30-2007, 10:54 AM
dragon370 dragon370 is offline
why?
here's a question: why is it that all the off-brand cheap stuff is higher wattage then name brand stuff? for example, i was looking at Lanzar (made by Pyle USA) amps last night. they make a 2 channel amp with 4000 watts peak and 1000 watts RMS @ 4 ohm. lotta power there. then i was looking up Alpine and Rockford amps. quite the opposite. the highest wattage 2 channel by Alpine was only 150 watts per channel RMS at 4 ohm! i cant remember what the highest Rockford amp i found in 2 channel was, but it was low as well.
so why is it that name-brand car audio stuff is so much lower power then off-brand stuff like Lanzar and Pyramid. this seems to be true with amps, subs, and speakers, but especially amps.
what gives???
Brendan
1993 Eagle Talon-ongoing project/DD
1979 Ford F250 long bed-rod through the block, awaiting new engine
Bad sex is better then a good day at work.
Old 03-30-2007, 11:36 AM
PlayStation3 PlayStation3 is offline
Re: why?
it's because company's lik alpine and rockford one put out a cleaner signal and too actully give out there rated power. one way you can tell if it is a b/s number is to check the fuse size cause 30 amp fuse can't support 1000 rms
Old 03-30-2007, 01:17 PM
doberman_52's Avatar
doberman_52 doberman_52 is offline
Send a message via MSN to doberman_52
Re: why?
Now I'm not sure, but I have heard that a lot of the quality stuff is under rated and a lot of the crap stuff is over rated, but I'm not sure.
1994 Honda Civic - D15B7 W/5 spd
2000 Olds Intrigue - 3.5
Cory
Old 03-30-2007, 01:46 PM
Re: why?
this is how i see it.:
crap stuff over rates there stuff and/or they go by there max watts not rms.
mainstream stuff ( like kicker mtx alpine rockford. usally put out around there rated rms.
Then there is the more upscale stuff like us amps etc where they will put out there rated power and then some like the us amps md2d is rated at 1500 rms at 1 ohm but one has been benched tested to be putting out 1950 at 1 ohm
Old 03-30-2007, 03:50 PM
bjboertje's Avatar
bjboertje bjboertje is offline
Re: why?
marketing
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 03-30-2007, 04:44 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: why?
Originally Posted by bjboertje
marketing
Exactly, your not going to get a $200 amp if it only produces 500rms, but if you can get a 1000 watt amp for $100 then why not.
Heres the reaon why there cheap
http://ampguts.realmofexcursion.com/Legacy_LA1020/
compare that to this
http://ampguts.realmofexcursion.com/Autotek_XS-900.4/
or this
http://ampguts.realmofexcursion.com/Zapco_AG_1000/
And heres some pics of a real 4k watt rms amp
http://ampguts.realmofexcursion.com/Autotek_MM4000.1D/.
All in all there after your money, consider what alot of them rate there stuff at to be 3-4 times the actual rating, if not more.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 03-30-2007, 04:52 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Re: why?
hahaha, 4000watts peak, 1000 watts rms...lotta power there.
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 03-30-2007, 04:59 PM
Re: why?
heres a 6k rms amp
http://cgi.ebay.com/REDUCED-US-Amps-...QQcmdZViewItem
Old 03-30-2007, 05:52 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: why?
CAR stereo equipment is not regulated in any mandatory way ..... so the manufacturers can legally write whatever power ratings they want on their amps or speakers. So the word for the day is caveat emptor - let the buyer beware.
Old 03-30-2007, 06:46 PM
Re: why?
I like internal pics better
http://ampguts.realmofexcursion.com/USAmps_Double_D/
Cardomain
Old 03-30-2007, 07:29 PM
Re: why?
dang i need to get me one of those. nothing like having a amp that has the same size wire guage inside of it as what i have for my power wire.
