Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-30-2007, 06:43 AM
recycle_me's Avatar
recycle_me recycle_me is offline
Send a message via ICQ to recycle_me Send a message via AIM to recycle_me Send a message via MSN to recycle_me Send a message via Yahoo to recycle_me
95 GS-T weird spark prob....
Ok so i bought a 95 2.0 SMALL turbo car and it is doing the whole not starting thing. New fuel pump also come on and pushed fuel through lines. I know this due to i took off the return hose and turned ove the engine and it shot fuel into to lil can i had sittin there. Also smells of awful gas when i turn over the engine. Now i know the it could be my coil packs but when i do the spark test, i get a spark when i first hit the key and none while holding the key and one more when i let go....so two total none during cranking. So im leaning to the ECM...but i also heard it might be the CAS no if my cas is bad doesnt that mean that i have crank walking......?Any help would be greatly app. Thanx in advanced.... Also is the ECM located behing the radio with 4 lil plugs comeing out? Any thing else i need to check?
For You Are Crunchy And Taste Good With Ketchup!
Old 03-30-2007, 07:48 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: 95 GS-T weird spark prob....
Yes, the ECU is located behind the radio. I would also check and see if the ECU is an EPROM while you have it out. DSMLink would be a great upgrade after you get the starting problem figured out, if the ECU is indeed an EPROM.
Someone correct me if I'm wrong, but the ECU won't turn on the fuel pump until it gets feedback from the CAS, if I remember correctly.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 03-30-2007, 12:19 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
That is correct indeed.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-30-2007, 05:38 PM
recycle_me's Avatar
so then the CAS is not my proble?? then maybe its coils or ecm....but if ecm was bad then i wouldnt be getting fuel correct?
Old 03-30-2007, 07:37 PM
recycle_me's Avatar
so i went to go pull the coils off and while i was in there i couldnt figure out how to get them out so i pulled the fuel rail and while i was in there i decided to see if the injectors were purging, turns out there not. Though i do have fuel going through the rail...just not out injectors. so does this mean i might have a bad ecm? also no eprom just a standard ecm p/n md309947. If anyone has a goos one just lying around and want to sell it........ let me know.
Old 03-31-2007, 03:29 PM
recycle_me's Avatar
so i cant find my cam angle sensor. i know hwere its supposed to be but its not there. just a black cap to plug hole. do i have a cam sensor or no?
Old 04-02-2007, 07:51 AM
You can find you CAS here:
http://members.shaw.ca/dsm.1000q/Eng...mer/2G/cas.htm
As for it being your problem, I'm not sure, but you should still check it out. I'm not sure what feedback the ECU is looking for when energizing the fuel pump, but it might not be as specific as the feedback needed for spark and fuel.
Other than the easy stuff like plugs and wires, the CAS is one of the more common problems associated with no spark. If you are also not getting fuel, I would definately check it out.
1997 Spyder GS-T
5-Speed
Old 04-03-2007, 10:24 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Don't necessarily count out your ECM. My car when it was dead, would pump fuel into the motor and turn over like it was going to crank it would just never start. I had spark fuel etc. As soon as I swapped in a new ecu it fired right up.
1991 GSX 2.3 Stroker
Old 04-05-2007, 05:51 AM
recycle_me's Avatar
Ok so yesterday i installed my new cam and crank sensors and got everything back togther. Aside from my plug wires being all messed up she ran and drove just fine. Not bad considering i only paid 800 dallars for this car and only thing wrong was a bad cam sensor. i went a head and replaced the seals on the cams and crank also replaced the timing belt and balance shaft belt along with waterpump and all that good stuf. Also while i was in there i went ahead and replace the crank sensor just to ease my mind once i got everthing togther. Only thing left is new plugs, wires, coils, and an oil change. Just wanted to let you guys know the problem and to thank you all for the help. Thanks.
Old 04-05-2007, 07:53 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Glad you got the problem figured out. You got one hell of a deal then.
Not to jack this thread, but for future reference. I, too, had this problem. My old ECM shorted out something. I didn't realize this, and swapped another in. The car still wouldn't start. I swapped mine back in (thinking it was fine, as the car was doing the same thing with the new ECU). I tested the ignition, and the coil pack and transistor packs were out of tolerance. I replaced them and the car still wouldn't start. I pulled my ECU apart this time. I discovered that there were black spots on it, and that apparently when it blew, it took out my ignition and AFC. After replacing the ignition and swapping in the other ECU (and removing the damaged AFC), the car fired right up.
(Another hint as to how close to having the car back together I am)
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 04-05-2007, 04:40 PM
recycle_me's Avatar
well took the car aroung the block today. got one hell of an oil leak so i have to take everything back apart to replace the front oil seal around crank but car has some decent acceleration for as many miles it has. but thanks agin for all help. guess ill learn to replace everytinh that could possiable go wrong while i have it apart huh. well lesson well learned.
