Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 03-30-2007, 03:55 AM
Sams68Camaro Sams68Camaro is offline
02 Tahoe dies while driving!!!
My 02 2WD Tahoe, with a 5.3 automatic, dies when you are driving. It happens when you put a load on it, passing a car or driving up a hill, etc. I have changed out the pressure sensor on top of the fuel pump with no luck. I took it to Autozone and had it tested, it shows a P0452 emissions low sensor level (what needs to be changed to fix this)? I have thought about the fuel rail pressure regulator, but it can get expensive when you start swaping out parts to eleminate possibilities. Has anyone out there had this problem before and fixed it, or open to ideas.
Thanks,
Sam
Old 03-30-2007, 02:06 PM
maxwedge maxwedge is offline
A990 racer
Re: 02 Tahoe dies while driving!!!
Welcome to AF, dies as quits or looses power? How old is the fuel filter, checked the fuel pressure under the conditions you experience. The code refers to the fuel tank pressure sensor mounted on the top of the tank.
Old 03-30-2007, 09:14 PM
It just dies and today I tried to start it with a 1/4 tank gas, all it did was crank, added gas and it started. I will try the pressure test and see what it is. Do you know what the pressure's should read normally under the different conditions?
Thanks,
Sam
