Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-29-2007, 09:59 PM
rs_green_machine's Avatar
rs_green_machine rs_green_machine is offline
Send a message via Yahoo to rs_green_machine
Unhappy can't seem to figure this out????
im working on my 95 rs n/t and a while back my idle started to surge between 1000 and 2000 up and down constantly and this is all after i just had the timing belt and all that goes with it changed ...i recieved info to change the I.A.C. so i did and there was no change and after sitting all winter while i was doing all the body and interior work its still doing the same thing! but i also have a new problem that i dont understand that is i went to change my plugs out ,on cylinder 1 and 4 the plugs were soaked with a milky or oily whitish liquid all over them and i was having a very hard time starting it (im thinkin due to this) but what i need to know is what can you gurus figure out , thanks alot
Old 03-29-2007, 10:32 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: can't seem to figure this out????
If there is oil on the outside of the plugs it could be your sparkplug seals leaking in the valvecover. You said they are kinda milky looking, sounds like water might have gotten in there also. If the car has been sitting for a while you should go ahead and give it a tune up and it should be fine. Except for the idle problem.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-29-2007, 10:48 PM
zornmiester zornmiester is offline
I had the same idle problem with my talon. Just by tinkering around with it, I found the the idle screw had vibrated loose. you just need to start the car, and adjust the screw till it sounds right.
Old 03-29-2007, 11:12 PM
i tried that but when i even ajust it a little it goes to like 3-3500 rpms and then takes forever to come back down?and the tb lever part that rests on the idle screw is right on it?????
Old 03-30-2007, 12:09 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Maybe you forgot to plug a sensor back in after the TB job? Sounds like you may also have a bad valve cover gasket and/or head gasket because of the coolant mixing with the oil and getting on the plugs.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
