Old 03-29-2007, 08:55 PM
osubuckeye osubuckeye is offline
Grand Voyager rear vent window won't close
I have a 1999 Plymouth Grand Voyager. The right rear vent window will not close. I'm not sure if it is the motor or the switch. The left works fine. Do the motors go out on these? How do I take off the interior panels to replace the motor if needed?
Thanks
Old 03-30-2007, 01:41 AM
KManiac's Avatar
KManiac KManiac is offline
Re: Grand Voyager rear vent window won't close
Here is what I want you to do. Have someone push against the window while another is operating the switch. I bet the window will close.
I had to replace both rear window motors in my 1998 T&C about four years ago. Then the motors were $70 a piece at the dealer. Mine would only open part way on their own. But if I pushed against the windows as they opened, they would open all the way. They would close all the way on their own.
You have to pull out the bottom and top pieces of plastic trim around the hatch opening. They snap in place. Then unscrew the rear shoulder belt anchors and any screws on the side trim panels, then pull them away from the body in the rear to reveal the window motors. You will have to remove A/C ducting on the passenger side to get at that motor. Simple tools will do the trick. This work took me about one hour to complete, without a manual.
Good luck and let us know if you have any other questions.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
Old 03-30-2007, 01:44 AM
KManiac's Avatar
With the name "osubuckeye", you must be from Ohio. I am originally from Parma and still wear the white socks.
Old 03-30-2007, 02:26 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
If the above doesn't work you can check the switch by removing the switch panel and check continuity using an ohmeter. On a schematic for a 98, there is a dark green wire and a grey wire going to the right rear vent motor. Find them on the harness connector and correlate them to the contacts on the switch. I'm hoping the circuit didn't change for 99. For comparison, the wires for the left motor are red with a white stripe and dark blue. You can check the motor windings from the disconnected harness plug. Should get several hundred ohms. If you get no reisistance, the motor is fried.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
