Old 03-29-2007, 04:16 PM
snuggles21777 snuggles21777 is offline
Do I need to remove the steering wheel to put a new turn signal switch in?
Its on the side of the steering wheel with the cruise control etc.
I was able to just buy the switch for 30.00 new.'
Its a 93 camaro, it has a small opening to get to the wires, but do i still need to pull the steering wheel.
The problem is the left turn signal stayed on, replaced the bulbs, sockets look good.
Forways work.
Thankyou 4 any help
Old 03-30-2007, 07:52 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Re: Do I need to remove the steering wheel to put a new turn signal switch in?
Welcome. I do believe the wheel does have to come off. If you have an airbag you have to go through the disarming procedures for that as well.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 03-30-2007, 08:02 PM
Okay, thankyou!
I WAS HOPING TO DO IT W/OUT PULLING THE WHEEL.
YEA IT HAS THE AIRBAG.
Old 03-31-2007, 02:18 AM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Hi snuggles! lol. that name made me laugh. I hope your female....
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 03-31-2007, 10:33 PM
giddyup50 giddyup50 is offline
MAKE SURE YOU DISCONECT THE BATTERY AND BE VERY CAREFUL WHEN YOU ARE WORKING ON THIS!!! Even with the battery disconected, there are still sensors that MAY be armed and COULD DEPLOY THE AIR-BAG right in your face!! I know these are two different cars but, when I replaced the multi-function switch (turnsignals, brights, hazards, wipers) in my 97 Taurus, I did not have to take the wheel off. I just had to take the cover off the colum. Your Chevy may be the same, or you may have to take the wheel off. I wouldn't know without looking at it. Make sure you get a Chiltons or Haynes maual and do everything it says in order. Just be carefull, EVEN WITH THE BATTERY DISCONECTED if you do something wrong, you could set off the air-bag right in your face!!
Old 04-01-2007, 05:05 AM
Wheel has to come off. GM used the same steering column assembly from the early 70's to 2002 in the f-bodies.
Yup, I own the suv.
