Old 03-28-2007, 09:03 PM
z24ridin''s Avatar
z24ridin' z24ridin' is offline
Exclamation Power Loss All Around
Hey I have a problem thats been bugging me for a while now. This is a 3.1 Z24. Even at idle I can definetly feel a lack in electrical power. The gauges dim to the idle. I can definetly tell a drop in stereo power. I have a newly installed CD player, but no amps or any type of system that would cause it. I also have a new battery, and nothing wrong with the terminals. I really need to get this situated because its so damn annoying and it cant be good. Any help would mean alot. thanks
Old 03-28-2007, 09:38 PM
01Cavy 01Cavy is offline
Send a message via AIM to 01Cavy
Re: Power Loss All Around
Check your altanator (sp?)
2001 Toyota Celica GT
Check out my CarDomain at...
http://www.cardomain.com/ride/2493960
Old 03-28-2007, 09:41 PM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Yep that could definitely be the alternator. Get it tested or nab a new one from a junkyard if possible and then go from there. How old is the battery?
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 03-28-2007, 10:34 PM
shakewell shakewell is offline
Have the alternator tested - if it's even borderline, replace it with a lifetime warranteed one. It's a GM so you will definitely want the lifetime one.
BTW, it's not the battery. But it wouldn't hurt to check the battery terminals for tightness.
Old 03-29-2007, 01:21 AM
PsychoJJ's Avatar
PsychoJJ PsychoJJ is offline
Send a message via AIM to PsychoJJ
Check terminal connections to make sure they are secure and there is no crap on them, alt., fuses (sometimes a bum fuse or two will cause things to act up) also you might want to look into picking up a grounding kit for the engine bay. My passenger side headlight was always dimmer then my driver side durring the day with the daytime running lights on and after I slapped the grounding kit in the car they are both the same now and everything else electrical wise cleaned up alot as well. This is one of the few things its totally cool to pick up off ebay for a steal.
Even pure genius is born out of insanity!
Big thanks to Lance for the sig pic.
Old 03-29-2007, 04:59 PM
z24ridin''s Avatar
thanks...... I just got the battery last week because it died on me but it was doing this before then. The terminals are as tight as possible, and nothings on them. I'll take the alternater off tomarrow and get it tested. thanks again.
