Old 03-28-2007, 08:26 PM
mannasugar mannasugar is offline
harmonic balancer bolt
I have an 89 Le Sabre, and I need to take off the bolt holding it on and it will not come off. Me and my brother used a 5 foot cheater bar and the bolt still will not break loose.
any suggestions?
Thank you
D.J.
Old 03-28-2007, 08:40 PM
3echo9 3echo9 is offline
Re: harmonic balancer bolt
Yes, this bolt can be a pain.
I added a three foot pipe to my breaker bar and lowered the car, using it's weight, to break the bolt free.
Good luck.
Old 03-29-2007, 07:24 AM
I do not have the cheater bar any more. Is it possible the bolt has reverse threads?
D.J.
Old 03-30-2007, 07:14 PM
Andrewhuffman Andrewhuffman is offline
mine didnt, i just jamed a wrench or i had a triangle shaped peice of steel between the compressor or water pump to stop it from slipping.
GT2560r's, Nismo 615cc, ARP Head Studs, UD Pulley, SouthBend Stage5 clutch, 60mm TB's, Ash-spec Tune, Specialty Z 3" DPs, HKS intake,
Energy Suspension, z1 Drive Shaft,E-fan, Port/Polished heads, AMS Manifolds, HKS SSQV BOVs, Howe Radiator, RPS segmented LW flywheel, UR OverDrive waterpump pulley, Billion Thermo, z1 silicone hoses, Stillen gauge pod w/autometers, D&S rotors all around
Old 03-31-2007, 10:41 AM
D.J.
Nope, it's not reversed threaded. I thought the same thing.
You don't have a cheater bar....ok.
I didn't either. You can look for any hollow piece of steel tubing. I used the handle from my jack and slipped it over my 1/2 inch drive handle.
Be sure to isolate the balancer from moving. I took off the little plate on the tranmission housing and wedged a screwdriver in the teeth of the wheel.
Good luck...you can do it!!
Old 04-02-2007, 10:06 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Impact gun
