| 240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
Quad cam VG30DET
So yeah, I had no idea this even existed. Why hasnt anyone done a swap for it yet?
It's out a of a cedric/gloria/something else.
Previously... --------| Now.... St185 GT4 Celica ---| SW20 MR2 Turbo Hardtop TT Z32 300zx ------| Rebuilt engine with race head TT Mitsu GTO ------| Apexi AVCR, Dual 2 1/2" Exhaust, T3/T4 turbo, BOV --------------------| Lowered King springs, Bilstein Struts & Shocks, Whiteline swaybars, Cusco Strutbraces --------------------| 17" Advanti Rims, Kenwood Stereo, 94+ Tailights K3:i have had this itch... the itch to bang a somewhat chunky girl... like i want it to jiggle a little |
Re: Quad cam VG30DET
older cima too i think, as well as the leopard and perhaps one other one... it's the fact that Nobody knows about them that they're not really popular, and most people that are doing the DE swap opt for the 300hp more common twin turbo.... i've been tossing around the idea of a 90ish cedric for a DD, as the GT's come with the det, altho i haven't been able to find one in a 5spd yet... still it'd be pretty cool i'd think.
the DE came in the 300zr's which were a VERY limited prod. run, but they never came turbo in them which is a damn shame... most of the zr's you see are in PRISTINE condition tho, which is pretty cool too (one day when i'm rich) but yeah they're pretty cool engines, aside from the dinky turbo, and the goofy twin entry intake setup... they could be modified, but without TTing it, there would be a lot of fabrication required for the intake setup to be in good working order.
ZedEx Crew Member #61988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc. blown turbo, under construction.. gt35 coming. |
Re: Quad cam VG30DET with Turbo
Yaggus, The VG30DET Turbo conversion has been completed by Ivan in Winchester, VA area in an 88 Shiro edition and possibly by others. The block is imported by ZFever.com in Florida and is extremely FAST. These engines were used in Cima's and Cedric's in Japan, were never imported in a completed vehicle. I believe the single turbo engines had ceramic fins, the engine had 2 throttle bodies and the output was around 400 Hp. The Quad Cam engine was a popular race version in Australia and Japan racing circles.
the vg30det in its stock form produced 222-255hp, and 198-236ftlbs with an N1 T3 turbo... which is definitely NOT capable of 400hp again it was used in the Cima, Cedric, Gloria and Leopard
I would assume the internals are the same or similar, however i can't find any reliable evidence to back this up, perhaps if you can find someone who has done the swap will know more and can further fill you in...
just to clarify, the t3 turbo isn't capable of the 400hp, the engine surely is with the right modifications however.. probably capable on stock fuel if it's similar to the dett.
umm....why? there is a quad cam VG30DETT which is more readily available and parts at the click of a mouse.
but yeah...i wonder how good the exhaust manifolds flow on it. wonder if it flows well enough to support GT35 series turbo. mmm...doubt it. Quote:
id like more details on the manifolds and oil pan...single turbo converted Z32 has potential for certain things. single TB'ed upper plenum would make it that much sweeter.
ZedEx Crew Member #4
what do you mean how well the exhaust manifolds flow? the stock z31t mani's are good to ~700hp apparently, which is way more than most will make, so i'm sure those mani's won't have any trouble flowing power... the only trouble would be fitting the larger turbo in there...
i'm thinking the only real difference for the aftermarket support would be the manifolds... there's a MUCH MUCH larger base for single turbos, and they're way fucking cheaper than twins, but i doubt there's a good set of exhaust mani's for it... and there isn't really anything for the intake plenums, aside from the extrude honed one in the first place, so no real difference there either.... and if need be you could always use the stock Y pipe from the DET to split into the 2 inlet dett plenum. it would be interesting to see if there are many/any internal differences between the two engines.
well, i guess not exactly not how much they will flow, i guess how efficient they will flow it. the stock manifolds on the VG30DETT will support 600rwhp im sure, but if you go with something better and more free flowing you could probably see a huge gain just because of the restrictiveness. id be interested to see VG30ET with stock manifolds and larger turbo and then a comparison with the a simple manifolds change being the only modification at the same boost level. i bet the power curve would look alot better, spool up would be extremely better, and there would be a very nice gain in peak numbers also. that Y pipe would be easy to replicate...i think a well designed single turbo, single TB VG30DE would bring performance to new levels in the Z32 market.
well, once i become proficient in solidworks, i'll have it for you in no time
you get the CAD software down, im gonna take a trip up to Canada so we can work on a few things. we could be rich with a few good ideas.
