Old 03-28-2007, 07:25 PM
Wardrivr Wardrivr is offline
Question Which Replacement Distributor Gear?
I have a stock '97 C1500 5.7L w/90k mi and need to replace the distributor gear. Should I use the AC Delco gear or the BW iron gear that's available. They're the same price.
Old 03-29-2007, 01:39 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Which Replacement Distributor Gear?
I would stick with the AC Delco.
But is not both steel gears?
Watch removal and installation.
180 degree off will throw the camshaft retard setting off.
Always check camshaft retard setting after engine is running.
MT
MT
Old 03-29-2007, 02:21 PM
Thanks MT. The original gear looked like steel, but Oreilly ordered me the iron gear by mistake. I was deciding if I wanted to use it or wait til probably next week before they could get me the AC Delco gear. I found a Chevy dealer that'll have me the factory part in the morning so I'm good now. By both do you mean the cam and distributor gear? The one that came in to oreilly was iron for sure. Roger that on setting the timing.
Old 03-29-2007, 02:30 PM
MT-2500's Avatar
AF - Advisor
On the both part I was wondering if BW or AC delco were the same?
Or one steel and the other cast iron?
Good Luck.
MT
MT
Old 03-29-2007, 02:40 PM
The original part looks like steel to me. The BWD part is iron. I'd rather replace the distributor gear than the cam any day!
Old 03-29-2007, 02:53 PM
I haven't seen the AC Delco replacement part. I thought it'd be steel, but it could be iron. I'll post what the dealer part turns out to be.
