1995 Stalls...in motion
Ok this is all second hand info.I have seen posts with a zetek engine,I dont know if he has one.He just said 4CYL.The owner is a pretty mechanically inclined guy.Does a lot of his own work.This one stumped him
![]() His sons contour stalls while driving.It acts like its not getting fuel...just quits.Here is the list of parts he has changed or had checked and meter'd good.crank sensor,cam sensor,TPS,IAC...had "firing" modual check'd its ok..Must mean ignition modual and the MAS sensor.He claims it can happen more quickly if he has all the acc's on too.He says he has to wait a "bit" +/- 5 mins before it will start. He has "popped" the strator valve and says the fuel dribbles out? .Thanks in advance for your time.
http://img164.imageshack.us/img164/841/97cvxd8.gif |
Re: 1995 Stalls...in motion
Fuel should literally spray out if you push in the shraeder valve. If its just dribbling out, thats not normal. Could be a fuel issue. Might want to replace the fuel filter and see if that helps since thats about a 5 minute fix.
![]() "The CEG Nazi" www.contour.org 1996 Ford Contour SE - Sold 3.0L V6 and Arizona Dyno Chip Turbo Kit 364 whp, 410 wtq @ 16 psi and only 4,700 rpms. 1999 Tropic Green SVT Contour - Bone stock and MINT |
The "external" Fuel filter has been replaced..sorry 4got to mention that.Is there an "internal" fuel filter in the tank....
http://www.contour.org/ubbthreads/sh...ue#Post1047078
Ok do we have to drop the tank or is it accessible from the trunk ?
http://www.contour.org/ubbthreads/sh...&o=365&fpart=1
He did the whole fuel pump.Lets see hows this goes over the weekend ....Thanks for your help
