Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-28-2007, 06:20 PM
emoontheinside emoontheinside is offline
Send a message via AIM to emoontheinside
Belt Replacement
When I checked my serpentine belt (or at least I assume its the serpentine belt) on the front of my 4.6L it's extremely worn and the ribbing is starting to crack. I know it needs replacing, but is it something I could do myself? If not, how much should I expect to pay elsewhere for it? I checked with a Ford Dealership and they wanted 90 dollars to do it and 48 dollars just for the belt.. :-/
Old 03-29-2007, 12:12 AM
351wStang's Avatar
351wStang 351wStang is offline
Re: Belt Replacement
A serp belt change is easy. Your car should have a diagram under the hood on the radiator support or on the underside of the hood showing how to route the belt. There should be a spring tensioner that keeps tension on the belt. I havent been under the hood of a newer mustang in a while so I cant remember for sure, but the tensioner should have a square hole in it. Just take a 3/8" drive ratchet put the drive part in the square hole. It may be 1/2" I cant remember for sure. But just rotate the tensioner away from the belt and slide the belt off of a pulley. Then route the new belt around the pullies like the old one was and your done.
1969 Cougar
357w & TKO - 475hp
