Old 10-10-2002, 05:21 PM
91Teg/99EX 91Teg/99EX is offline
Send a message via AIM to 91Teg/99EX
Question about turning off front signals
I tried doing a search but cant find the right words to use for the search
my question is...
is there a way to turn off the front signals for the 99-00 gen civic's when the headlights are on? (mainly because my side bulbs look really dim since I blackhoused the reflector) Basically i want to turn off my turn signals only when it's not turning
Thanks
TO DO list...... add mods...
Done list........ Lighting
Old 10-10-2002, 06:08 PM
NuEra's Avatar
NuEra NuEra is offline
Banned
Damn, I thought I was the only one. Don't bite.
Old 10-10-2002, 06:10 PM
NuEra's Avatar
Banned
Actually, I would tell you but mine is a 98 and the wiring harness is probably different.
Old 10-10-2002, 07:34 PM
hahah ... was it hard to do what you did to the blinkers?
Old 10-10-2002, 07:42 PM
sonni_kuba sonni_kuba is offline
Yes it is possible
Since your bulb has two filaments (5W and 21W) you will disable the power supply feeding the 5W -> this powers the so-called 'Parking Lights'
the 21W filament is responsible for your turn signal 'blink'.
You have to unscrew the bulb+socket from the inside. You will find that you have three wires attached to it.
I believe the colors should be green, red, and black.
I know that the black is the ground, try snipping either the green or the red (you make the call). You have a 50% chance of guessing right. Then, try turning on your headlights, to see if the corner light turns on. If it does congratulations, if it doesn't connect the cut wire and cut the other one.
Hope this helps,
Kuba
Old 10-11-2002, 07:30 AM
NuEra's Avatar
Banned
I never heard of that way but I guess that would work for your 99-00. The way I did it dealt with crossing wires on the stearing column and it was the easiest thing I did so far. The way this guy describes sounds fine.
94 Lincoln Continental: Lights won't turn off TheWampusCat Continental 8 01-12-2014 10:56 AM
question about 1993 lesabre jessitrzeb LeSabre 7 04-03-2010 01:49 AM
Question about turn signal red/orange McLin Lumina 2 03-08-2010 02:24 AM
Can't turn off left signal turn light? Eddy1 Suburban 0 08-27-2005 10:22 AM
