Old 03-28-2007, 02:23 PM
landark landark is offline
grand caravan 2000 window problem
how do I get right front door panel off to repair window
Old 03-28-2007, 08:36 PM
UncleBob UncleBob is offline
AF -Advisor
Re: grand caravan 2000 window problem
carefully.
Really, its like any door panel. There will be at least a couple screws hiding about, possible a panel at the door lever that needs to be removed. Then, you need to pry the panel away, and the plastic fasteners holding it in place will release. Sometimes they break apon pulling it away, and there's not a whole lot you can do about it. I could suggest expensive tools to help reduce that, but its much cheaper to just replace the few fasteners that might break. Or you can just ignore them too
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 03-29-2007, 03:19 AM
Thumbs up Re: grand caravan 2000 window problem
appreciate your imput, but I already got it off, have another question, I checked the relay swich, and power is going through it, so it must be the motor thats the proplem. Any sugustiioon on how to tell if is bad. I'm not really stupid. but I'm a 68 yr. old women who is still learning how to do my own repairs. Thanks, Landark
Old 03-29-2007, 03:51 AM
AF -Advisor
simply put power directly to the motor. Both directions. If it does nothing with that, then its a pretty fair bet the motor is shot. Although it could be the regulator
