Go Back   Automotive Forums Car Chat > Hyundai > Excel
Old 03-28-2007, 04:00 AM
lynchie05 lynchie05 is offline
Unhappy can someone PLEASE HELP
I have a excel twin cam 98 glx 4 door, All was great with the car until 1 day i stopped it and when i went to start it again it wouldnt go, after leaving it for awhile it went a few days later the same thing happened.
then a few days after that i was driveing and slowed down for a red light and it stopped again, if i leave the car for around 30 mins it will start again but this is happening alot more offen.
sometimes the car will go for 50klm and other time just 2.
I have changed the fuel filter and fuel pump but this is still happening can ANYONE PLEASE HELP ME
Old 02-23-2008, 12:53 PM
dmiller66 dmiller66 is offline
Re: can someone PLEASE HELP
Hey, sounds like you might have a bad ignition coil.
Old 03-24-2008, 12:28 AM
wopstar wopstar is offline
Sounds like a crankshaft sensor, it doesnt bring up the engine light but when it is faulty it heats up and stops working causing the engine to cut out. When the engine gets cold the car will start. Had this problem at work couple of days ago. New sensor fixed the problem.
Old 04-04-2008, 11:10 AM
fendermarshallvox fendermarshallvox is offline
there are no 98 excels, are you sure its not an accent
Old 08-17-2008, 03:44 PM
jcaxe's Avatar
jcaxe jcaxe is offline
When you say it stops and won't go, does the starter engage or is it completely dead. If the later, you could just have a loose battery cable or perhaps the wire insulation is damaged allowing it to short out against the block.
Old 11-21-2009, 06:16 AM
Pack1t Pack1t is offline
Sup,
My sis had a similar problem, She was told to get the tank looked at, but we noticed that it was only happening when the petrol tank was low, not empty but under a quarter tank.
When she keep the fuel high, it doesn't happen, and she hasn't had any problems with it for a few months, so i guess that might have worked.
Sorry if this doesn't work? it worked for my sis for some reason?
thx
Old 12-22-2009, 03:22 PM
Clamdober Clamdober is offline
I have the same thing with my 01 Tiburon right now. Turns out the crank shaft is banging against something. That's $2500 if that is what it is. Hopefully you're under warranty. They're trying to get me on mine because I can't find an oil change reciept from 10k miles ago... lame right. I've had 2 since and they never noticed a problem >< I think they just don't wanna pay the piper.
The other odd thing it may be is a Flywheel (sp) problem, if it seems to randomly stall out like that. Again, my 01 Tiburon had that problem also right off the lot. I bought it at 17 miles and they couldn't figure out why my car was randomly stalling out or not starting until around 500 miles.
That's all I have for you. No idea what the amount of gas would have to do with anything unless there's water in the tank.
