Old 03-27-2007, 09:49 PM
mygreenTT's Avatar
mygreenTT mygreenTT is offline
Send a message via AIM to mygreenTT
i cant figure it out...
i took the bezel out today to take out the crappy glow gauges the previous owner had in, after i got them off i put the needle back on the tac. when i put it in acc the tac jumps to 3k, when i start it she idles at 4500. it's quite annoying. any remedies?
93 3000GT VR4
blitz dsbc @ 1 bar
blitz turbo timer
autometer boost and a/f gauge on a pillar
greddy type s bov
NGK iridiums w/ NGK wires
3SX DP, 3" stainless single shot
drilled and slotted rotors w/ hawk pads, steel braided lines
supra pump hot wired
SPEC 3 clutch
PTE 550cc injectors
SAFC II
IPS tubular manifolds
evo3 16g snails
converted sidemounts courtesy of oohnoo
built and tuned by jeremy and keith at WSR
Old 03-27-2007, 10:23 PM
X2Xtreme360 X2Xtreme360 is offline
Re: i cant figure it out...
I'm guessing you just pulled the needle off and put it back on. It works from a spring and you have to mark off where you pulled the needle off. 3k really means 1k, and when you idle at 4,500 that really means 1,500. I would reccommend turning the car on so the tac is working, then pull off the needle and reattach it in the right spot, which would be wherever your car normally idles at when it's started.
Current mods:
Cold air intake
Magnecor 8.5mm competition wires
NGK copper spark plugs
Polished Plenum
KillerGlass radiator hose
Old 03-28-2007, 07:17 AM
mygreenTT's Avatar
thanks for the tip, i will try that this afternoon
93 3000GT VR4
blitz dsbc @ 1 bar
blitz turbo timer
greddy type s bov
SPEC 3 clutch
PTE 550cc injectors
SAFC II
evo3 16g snails
Old 03-28-2007, 03:39 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
?? if 3k was 1k... then 4.5k would be 2.5k... if i am not mistaken.. and if that is the case i dont think that it is your needle..
Old 03-28-2007, 04:14 PM
AutostradaVR4 AutostradaVR4 is offline
i think he meant 3k would be the bottom of the tach normally...or "0k", which would make sense if it jumps there when he turns the ignition on
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 03-29-2007, 07:55 AM
Yea you can't really calibrate the needle without the Acc on because it won't won't work in his case. I meant with the car on the 3k mark would be about 1k and 4500 would mean 1500
Current mods:
Cold air intake
Polished Plenum
