Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-27-2007, 05:13 PM
callens callens is offline
OBD2 conversion.
I have a 1995 (OBDI) Oldsmobile Delta 88 that I have converted to 1997 OBD2 (yes, I replaced the complete wiring harness) and had it programmed to be 1998 or 1999 Delta 88. I had to us a VIN that maintained the ABS, Theft Deterrent and fuel pump control (one speed). It took many months of investigation to do this.
First, how can I find out what VIN the ECM was flashed with, I gave the guy a list and he never told me which one he used.
Second, the engine was off a 2000 GM test auction, no ID was ever stamped on the block, but the transmission mentions that it has a 3.0X final ratio (I though it was 1 but I have to look up the picture of the plaque) which the ECM is not programmed for. It is programmed for a 2.X final ratio. This make the torque converter stay at almost full pressure shifts, yeah it jolts the dash ever time.
Third, how can I get the ECM flashed with the different ratio to stop the slamming into gear and keep the compatibility for all other components?
I suspect GM will have to make a special VIN program for this to work. But who and where can I get help?
Old 03-27-2007, 06:46 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: OBD2 conversion.
Wrong section, try the olds guys they will probably be more helpful
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 03-27-2007, 08:44 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Whats the purpose of converting to OBD2
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-28-2007, 08:44 AM
If you could, I am new at this, how do I put this in a Oldsmobile forum? I had no clue that it went into the wrong forum. The menu system and structure on this site is quite vague.
Old 03-28-2007, 09:14 AM
blk_srt's Avatar
http://www.automotiveforums.com/vbul...play.php?f=764
Mods:
