Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 03-27-2007, 03:01 PM
its_4me its_4me is offline
Question Engine Swap-98auto to a 95 manual?
Can anyone tell me if it is possible to put a motor from a 1998 Neon w/Auto trans,into a 1995 Neon w/Manual trans? and/or what would be needed? any Information You can give me will be more than I have now. Thank you
Old 03-28-2007, 08:28 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Engine Swap-98auto to a 95 manual?
Yes it's possible. You will need the engine wiring harness for the 98 engine as well.
Are you swapping trannies as well or just the engine?
2003 Dodge SRT-4
Old 03-29-2007, 02:34 PM
Thank you for the info. If you only knew the # of people/places ive called and nobody had the answer. thanks again.
As for the trannies, I'd planned on sticking with the manual
Old 03-29-2007, 03:58 PM
If you are swapping the 98 motor into the 95, then swap the engine haness as well and you will need a 97-99 manual PCM, either SOHC or DOHC depending on the engine.
2003 Dodge SRT-4
