b18 motor problem, HELP!
oil got into my spark plugs(3,4cyl) wat went wrong?
Re: b18 motor problem, HELP!
have you checked the inside of your head?, look for the spark plug O rings
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR |
well dude if you continue experiencin problems, ill ask my buddy, hes a master tech at honda. just get back to me if you need anything else
i had a problem very similar, check for excessive blowbye, oil came out of the tube that leads to my intake and went in trough the intake and was injected into the cylinders, so try plugging the tube to see what happens, then go from there
My question is this, where on the spark plug is the oil, on the threaded part towards the inside, or the bolt head part towards teh plug wire?
check your valve cover gasket my 92 ls did the same thing i replaced the valve cover gasket and it went away
