Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 03-27-2007, 11:10 AM
THEO529 THEO529 is offline
2000 Bonneville:Windows/door locks and right mirror not working
I also have a 2000 boneville and over the winter i discovered that those same three windows/locks/courtesy lamps doesnt work , I have went through all the fuses which are fine , I will call the dealership and check on the BCM. I also have the wet floor problem . but no sun roof , can anyone tell me what the problem might be for that issue , I read that it may be the connector under the pass seat , i see a connector above the carpet, could that be it or is it located under the carpet
Old 05-01-2007, 02:58 AM
BONNEVILLEMADRID BONNEVILLEMADRID is offline
Re: 2000 Bonneville:Windows/door locks and right mirror not working
Hello,I have the same problem as you,only the driverīs door window and door lock works,and i would like to know if finally you found the problem .
Thanks
Old 05-01-2007, 11:03 AM
ru1313 ru1313 is offline
Cool Re: 2000 Bonneville:Windows/door locks and right mirror not working
Check the grounding connections under the carpet on each side of the car, driver and passenger remove the door moulding lift the carpet and the wire harness on each side has a ground on the passenger side its for the fuel pump, windows and the drivers is windows power seats and who knows what else. good luck by the way check the windshield its probably were the water is coming from.
ru1313
Old 05-02-2007, 07:52 PM
jdq jdq is offline
Another possibility is inside your door skin there is a clear piece like plastic and is sealed with a butyl sealant ( black caulking) it may have come away from the door and not sealing.Pour water around window / door area while open and see if water comes out bottom.If you notice floor pretty wet it is probably soaked as there is a thick padding under carpet and there has to be alot of water to soak thru.I had to remove carpet to dry.
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 09-20-2009, 11:54 AM
2000BlkBonneville 2000BlkBonneville is offline
Has any figured this problem out yet i have a 2000 bonneville SSEI driver door works fine pass no window or lock and back doors also do not work i have pulled passanger side seat and checked that is no it anything else that can be done
Old 09-02-2012, 12:25 PM
dontgetcaught dontgetcaught is offline
This is a common problem and the answer is found on this website:
http://www.autotechonwheels.com/2010...itching-it-up/
Old 09-05-2012, 07:20 PM
Jrs3800 Jrs3800 is offline
Very common problem with that ground bus under the drivers seat... Its one place I would check for sure...
Old 09-08-2012, 07:13 AM
Billy J Billy J is offline
Hey guys. I just went through the same thing. to think every one is right about the grounds. I fixed mine by pulling the kick panels both left and right, pulled apart the buss connector ,cleaned and soldered all spades .these are the main grounds . also on the pass side is the relays for fuelpump. water from windsheld can drip down into this relay and fuse and corrode . also there is a ground buss in the trunk, do the same as above .Same goes for trucks and Suv. Water is the main prob ,windshield seals are no good as it gets hard over time and pulls away causing the leaks. Peace!
Old 09-08-2012, 07:20 AM
even though these connectors may look okay but they can become lose over time by just shutting the door. It's worth the time to remove the plastic cover to expose the spades and jumper bar and clean and SOLDER. you might be surprised how many things you'll fix just buy doing this.
