Seat belt light...
My fasten seat belt light has stopped working, ive tried three other bulbs that i know were good at i still couldnt get it to come on. i noticed right before it stopped working though that it would be really dim when it would be on for a few seconds. just wondering what else i should check. is there a sensor in the seat or something that makes it light also?? i know its just the seatbelt light and its not a big deal but i want to really maintain the stock look of the car by having everything good. any help would be great.
2006 Chevy Cobalt LS |
Re: Seat belt light...
As I recall, the '83 used a cam switch in the seat belt winder instead of a switch in the seat belt receiver. It was right about that time that models were changing over. Either way, the circuit is routed through a switch for the seat belts, and the end of the seat belt with the wires will be the one to investigate.
well the one on my 84 stays on constantly, so consider yourself lucky.
yeah i geuss, so ill have to look around where the seat belt winds up into then?
yeah
k thx
onle last thing, how to i remove the plastic cover over the seatbelt windup?? i see a few screws but i dont want to mess up anything either
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Alright ill look eveything over and get back to you all. thanks for the info
I thought on these old cars that the light was on a timer or something and only came on for a couple of seconds when the key is first turned reguardless if the seatbelt is clicked/extended out or not. its really run through a switch though isn't it?
