Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 03-26-2007, 10:26 PM
chevcamaro_86 chevcamaro_86 is offline
Thumbs up engine modification
i know that a grand am wasnt ment to be a race car but its all i got and i want it to be faster it is a 95 3.1l v6 i got a short ram cold air intake and modified exaust. i was wondering if i port and polished the intake manifold and heads how much power would i bee gaining and is it even worth it? i was wondering also if i could just take the heads of 3.4l pontiac cause i believe the blocks are the same? if i did would that help me i also looked at some cams looks affordable but what should i get? any help appreciated.
Old 03-26-2007, 10:42 PM
scoopy03 scoopy03 is offline
Re: engine modification
the upper block of both the 3100 and 3400 are the same. heads and up can be interchangeable. you can get a bigger 62mm or a 65mm throttle body. here's some more infomation on 3100 to 3400 and links to help you out. http://members.shaw.ca/lloydcharvey/...3.1lto3400.htm
http://www.doctorspeed.com/grand_am/...ttle-body.html
http://60degreev6.com/store/index.ph...d&productId=24
do you got full exhaust or just headers or cat-back exhaust? you can get a turbocharger for your also.
http://www.turbochargedpower.com/99-04%20Grand%20Am.htm
or the easiest way would be get a 4t65e tranny and a 3.8l supercharged engine out of a rivera or a park avenue. that's exactly what i did.
99 olds alero 2.4 DD
92 notchback with 460 carb'ed
Old 03-27-2007, 08:11 PM
sounds good but if i change engines what happens to the computer stuff and sensors and what about the port and polish?
Old 03-27-2007, 08:25 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
This site has intakes and heads that would increase HP.
http://milzymotorsports.com/
It is very expensive for engine modifications.
If you do get any heads I would suggest getting the chromoly push rods.
Your trany is a 4t60 which is better then the newr 4t40-4t45's which are in N-bodies,
they are weak and dont like over 200hp.
Also that turbo is not available right now
check out my cardomain below, it has my list of mods on the SE sleeper.
1999 Grand Am SS 3.4 OHV
Old 03-29-2007, 05:43 PM
Busymandan15 Busymandan15 is offline
Send a message via AIM to Busymandan15
Does anyone know how to take off the Gov off the 3400 V6 Alero? Its a 2004 and i cant find anything on it. And is the Cold air intake a good investment?
Old 03-29-2007, 06:49 PM
Welcome to AF Busymandan15 !
The limiter is not something that can just be removed.
The only thing you can do is raise the limit,
which a stock PCM usually cant be changed perminatly.
Though thier are aftermarket PCM's that can be altered for the better
IMO , yes a CAI is worth the money.
Old 03-29-2007, 07:02 PM
So i found Milzy Motorsports and they have PCM for my car. Now is my car a 3.4 DOHC or just the 3400 series? I dont know i was confused when i saw that?!
Old 03-29-2007, 10:14 PM
Your car is the 3400 OHV not the DOHC .
Though after you get the DHP PCM you will need it tuned.
A dealer or other qualified shop will have to do this,
unless you have some sort of software or the DHP tuner,
that is sold at parts for your car,
which they also sell the PCM's.
This isnt cheap though
But when you get it tuned they can raise the Govner.
Old 04-11-2007, 07:08 PM
xxgraffixx xxgraffixx is offline
will the super charger fit a 3.4 2001 g.a and i also want to turbo it but i had probs when i turboed my 95 3.1
Old 04-11-2007, 07:28 PM
If it is a superchager for the 3.4 it will fit and work jsut as the turbo that is "made to fit" the Grand am if you can find one.
Not some cheapo turbo / super charger kit that needs fabricated and doesnt even come with turbo headers.
Old 04-19-2007, 03:01 PM
grandma grandma is offline
Send a message via AIM to grandma Send a message via Yahoo to grandma
Most people never got a complete kit from those guys. One of the R&D cars used to post on www.grandamgt.com and he definitely was a bit bitter towards those guys. Looked nice but good luck getting a complete kit.
'01 Pontiac Grand Am
GT30R powered 2.4L quad 4
432hp 424tq
Closed Thread
