Old 03-26-2007, 08:57 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Wheel problem
When i got my free 90 lx sedan, i noticied the drivers side wheel (while driving) felt like it was bouncing up and down or wobbling. The steering wheel would rock back and forth pretty harsh. So the other day I put some new rims a buddy had and drove the car agian, same thing. So doing this, it eliminates the problem being the rim. I also noticied that I the cv boot towards the hub was cracked open and when I put my hand on the axle, It had some freeplay in it. So what should I be looking at here? Need some advice!
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 03-27-2007, 12:13 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: Wheel problem
Is the boot busted? If so, replace your axle. Does it always vibrate or just when you hit the brakes?
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 03-27-2007, 12:25 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Wheel problem
if there is free play up and down then your axle isnt sitting centered and itll shake the whole car, those axles are heavy. The drivers side axle on these things are also quite long and can generate some serious leverage on the car if they arent perfect.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-27-2007, 01:23 PM
stnapycnaf stnapycnaf is offline
Re: Wheel problem
could it possibly be your wheel bearing?
91 CRX HF
D16A6 Swap
Old 03-27-2007, 05:21 PM
FrodoGT's Avatar
Re: Wheel problem
If it is, you sure as hell should hear it. And the car is probably pulling like a bitch.
Current project:
Rio Red 91 hatch.
