Old 03-26-2007, 03:14 PM
ttownjoeshow ttownjoeshow is offline
93 Dynasty running rich!!! Help!
Hi i'm new!! i'm mostly a toyota 4X4 guy....
so my friends Dynasty is running pretty rich, when it does run....it doesn't run for long (once its hot she doesn't want to start, but with pumping the gas she will and puff black fogs, and spit n sputter), me and a friend have been leaning towards the mass airflow sensor. thinkin its sayin that theres lots of air flowing through, ya kow? so i'm hunting for a M.A.S or is it M.A.P.? oh and this is a 93 3.3L Dynasty, i read alittle about the 4spd trannys being alittle on the crappy side but doesn't apply to this problem. any expierienced help would b greatly appreciated!!
Old 03-28-2007, 12:04 AM
UncleBob UncleBob is offline
AF -Advisor
Re: 93 Dynasty running rich!!! Help!
could be the MAF, but I would definitely check the air snorkel between the MAF and throttle body for splits, leaks, or disconnected lines.
There's a few other things that could cause a real rich conditions, such as bad O2's, bad fuel pressure regulators, bad coolant/intake temp sensors.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 03-28-2007, 07:35 AM
well i'm alittle lost, i phoned a used parts place and they told me that there was no such part for that year/model!! it turns out that the part that i thought was the mass aif flow senser is a engine computer, according to the haynes manual. i phoned up my mechanic/friend and he said to start at the catalatic converter, if that doesn't do it then the M.A.P. senser.....the only problem is that her and i are broke, so it just makes it that much worse!! lol
I thank You for your help!! i'll definatly b checking them parts too!! hopefully this weekend we can get it done!!
Old 03-28-2007, 11:33 PM
Kurtdg19's Avatar
Kurtdg19 Kurtdg19 is offline
Send a message via AIM to Kurtdg19
First and foremost, definately check for any leaks in the air snorkel and disconnected lines as UncleBob stated. Then go to the catalytic converter as the symptoms your describing really sound like it could be related to it. Its always best to check the easiest things first, so check for air leaks in the snorkel..etc. first before you have to break your back underneath the beast
I know my old 88 pontiac firebird's converter has been clogged before and was doing very similar things that you've stated the dynasty is doing.
http://www.thepartsbin.com/catalytic_converters.html Check this link out, it could possibly help you out.
If that helps but your still experiencing rough running you may want to check the O2 sensor while your underneath the beast checking the converter. Usually the O2 sensor doesn't start to kick in until the coolent temp sensor tells the cpu the car is warmed up. So the O2 could be causing some problems once your car gets into a warm enough operating range and the cpu begins to take the O2 sensor into consideration. Also the cpu usually ignores the O2 sensor during wide open throttle conditions (since maximum throttle will require a lot of enrichment). That could possibly explain why the car will still run when you pump the throttle to keep it going. Of coarse this is all speculation and its hard to tell what it is without being there. Its definately worth a look if your down there anyways.
Good luck!
Your powerband ends at 6?.....funny......
thats when mine starts.
Old 03-29-2007, 10:00 AM
Thanks a million guys!!!! changed a wack of sencers and its fine now!!!! thanks again!!!
