Old 03-26-2007, 02:02 PM
toolhead toolhead is offline
Send a message via AIM to toolhead
Question blue smoke?
sorry to be asking all these questions but i keep finding stuff that a second opinion wouldnt hurt. anyway i noticed today that my car wasnt boosting like it was. in first gear it boosts fine but when i let off the gas at the end of the gear in wot and look behind me i see a puff of blue smoke then when im in second it will boost fine for the first half of the gear then it makes a weird noise and doesnt pull like it should. so i let off and another puff of blue smoke. so i was woundering what could the blue smoke be? i was thinking oil. but not knowing from were. and the second question is if the blue smoke could relate to the low boost? and i think thats all. so let me know what you think
Old 03-26-2007, 02:17 PM
ZRYDERVR4's Avatar
ZRYDERVR4 ZRYDERVR4 is offline
Re: blue smoke?
awhile ago there was a forum with the same problem i think it was oil that was make the blue smoke, like a oil leak leak in the turbos or something like that.
and idk about the boost tho
Old 03-26-2007, 02:20 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: blue smoke?
Blue smoke is burning oil. Check your turbos to make sure it isn't leaking from them.
Old 03-26-2007, 02:33 PM
vectorspecialist vectorspecialist is offline
Re: blue smoke?
blue is oil, i had white smoke and still have it.
Old 03-26-2007, 02:37 PM
Polygon's Avatar
The Red Baron
Re: blue smoke?
That would most likely be steam which is burning coolant.
Old 03-26-2007, 04:34 PM
Re: blue smoke?
that or i've also thought maybe it's water getting into the exhaust pipe's(sadly it sits outside) and as the exhaust heats up, its burning the water off
Old 03-26-2007, 05:52 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: blue smoke?
yes, blue is oil, white is coolant.
if your burning oil, it could be at any one of several places: turbos, valve stem seals (VSS), rings. most likely the VSS: the turbo cars have this problem around 120k miles. how many miles are on your car?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 03-26-2007, 11:11 PM
Igovert500's Avatar
blue + red light magnet
Re: blue smoke?
yeah but the fact that he's blowing out oil when he shifts, and he isn't boosting all that well, are kinda hinting more towards turbos, not vss. VSS leaks would be more prevalent at start up. Not to say it's one or the other, frankly it could be all 3.
Best bet is to pressure test it and do a compression test. See where you're at.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-27-2007, 07:35 AM
Re: blue smoke?
does it smoke at all when u accelerate or just wen u shift
Old 03-27-2007, 08:12 PM
Re: blue smoke?
it smokes when i accelerate to. but i noticed it when i was shifting
