Old 10-10-2002, 09:43 AM
gcheok gcheok is offline
Question (might seem stupid)
Hi all,
Stumble upon this forum while surfing the web. And I like the environment here, especially the pics of the models you guys built, really make me want to build one that nice.
Anyway, here's my question, do you paint the parts first then cement them together or do you cement them then paint them?
Problem with painting first then cementing the parts is that the paint might come off and merge with other colors. While it will be difficult to paint the parts when they are cemented together already. Any advise or comments greatly appreciated.
Thanks.
P.S. now I know I must use primer to make them shinny, have been doing a few without primer, no wonder they don't shine at all, will take some pics and post them soon.
Old 10-10-2002, 10:22 AM
MaxSE's Avatar
MaxSE MaxSE is offline
In all cases i prefer to paint then cement. Which i can imagine is what most people do here. The only exeception in my case would be the rear view mirrors which i prefer to cement first if they are going to be color coordinated with the body. Or else i stick to the above rule!
Welcome to AF:ylsuper
Say NO to wheel gap...
Old 10-10-2002, 09:06 PM
fatboyslim's Avatar
fatboyslim fatboyslim is offline
WELCOME To AF!!
No question is stupid!!
Take a look at the FAQ's at the top of the thread list most things are covered there!
If you need any help just ask we're a fairly nice bunch of guys and gals and will always help a newbie!!
See my models, click on HOMEPAGE below
Old 10-10-2002, 10:36 PM
COZMO6476's Avatar
COZMO6476 COZMO6476 is offline
i say it depends on the parts. for example on the one hand, i would glue the two halves of an engine together first so that i can match up the seams and putty if necessary. then i paint it. on the other hand, when dealing with complex parts like suspension, i paint first, then glue since its easier to access the different complex parts individually before they are glued. you just have to see what would be easiest for the given situation. hope that helps
Old 10-10-2002, 10:41 PM
djmr2's Avatar
djmr2 djmr2 is offline
Re: Question (might seem stupid)
Originally posted by gcheok
Thanks.
Primer does not make ur paint shiny. Primer gives paint something to hold onto, rather than trying to hold onto smooth plastic.
Old 10-11-2002, 11:47 AM
Thanks guys for the advice!
Will know what to do for my next model. In the meantime, will be posting some pics of the models I made....please give comments and advice.
BTW, what makes a car shine if it isn't primer?
Old 10-11-2002, 11:48 AM
Forhod's Avatar
Forhod Forhod is offline
Tamiya Acylic Paint.
They shine!~
Old 10-11-2002, 01:27 PM
Daryl's Avatar
Daryl Daryl is offline
An even coat of paint and a good polish
Left is right. Right is wrong.
Old 10-11-2002, 01:31 PM
MaukaRunner MaukaRunner is offline
Send a message via AIM to MaukaRunner
Paint shine
Paint shine is dependent on a lot of things. Mostly it's how close you spray the paint. The farther away you spray the paint will probably be dry when it hits the surface. Try practicing on a scrap piece of plastic to get familiar on how far to spray. The nicer the paint is initially, the easier to get a mirror smooth surface thru polishing.
I've gotten even egg shell type paint to shine like a mirror. If you are still on the color coat, try using clear and using a polishing kit. I like to use Lacquer paint so I can use automotive polishes and compounds. Good luck!
Old 10-11-2002, 02:29 PM
tonioseven's Avatar
Talking Welcome to AF!!!
There are no stupid questions when it comes to modeling; that's how we get better!!!
Old 10-11-2002, 10:17 PM
Thanks for the advice guys, you a great bunch!
I have another question, how do I distinguish between acrylic, lacquer etc spray?
The paint I normally spray on the body is Mr Color or Tamiya spray can. Are these acrylic or lacquer?
Also, I have tried using clear coat but after I spray it, it makes the car matt instead of shiny. The clear coat I used is Mr Color Clear Coat Super Glossy. Is there a certain technique in spraying clear coat? Please advice. TIA
Another car stereo question Speculant Car Audio 11 08-18-2010 06:37 PM
2000 E150 question ZZT Econoline 1 11-25-2009 11:15 AM
exhaust question 89corollajoke Corolla/Matrix/Voltz 2 07-08-2009 11:22 AM
This might seem silly but countach79 Car Modeling 21 09-28-2007 03:59 PM
I know this might seem funny to you guys, but please help me.... Suffakate Accord/TSX/Accord Hybrid 3 02-17-2005 08:45 AM
