my parts list
Rotating assembly from Ohio Crankshaft 383/408 SBC Super Kit * 350 0r 400 mains * OC 4340 3.75" Crank * OC 6" H-beam rods * SRP Flat top pistons * Total Seal Moly Rings * Internally Balanced * READY TO ASSEMBLE *$1699 AFR 195 street heads/straight plug/74 cc combustion chamber 033-1036J - 1,440.99 Edlebrock RPM AIR GAP- 209.88 EDL-7501 Edlebrock Carb 750 cfm/square bore/electric choke-299.99 EDL-1411 Fel Pro Head gasket-52.69 FPP-1043 ARP- Head bolts -59.95 ARP-134-3601 ARP- Engine accessories fastener kit- 75.95 ARP-534-9701 Lunati Voodoo camshaft/lifter kit- 189.95 LUN-60104LK Summit Roller tip steel rocker arms 1.5:1- 89.95 SUM-141506 Rocker Arm studs, ARP- 35.95 ARP-134-7101 Summit Timing chain - 31.95 SUM-G6600 Summit SFI Harmonic balancer- 104.95 SUM-C4265 Summit oil pan kit- high volume moroso pan/pump- 175.95 SES-3-60-08-540 Mildon Timing chain cover-stell/chrome plated- 23.39 MIL-65500 Water Pump-chrome- 63.95 SUM-G1650 Fuel Pump- Carter 120gph- 19.95 CRT-M4685 The feeling in my pants when its all done. Priceless. I still have more stuff to get but this is most of it. __________________
1968 Camaro 327 1999 Silverado 1500 Z71 LT {o,o} |)__) -"-"- O RLY? http://www.cardomain.com/id/korndogg002
Re: my parts list
lookin good doggkorn, BTW forgot to ask the other night, why didnt you just order a complete gasket kit, since pistons wernt fitted to block make sure you double check piston to wall clearance and all that stuffs and whatnot, high volume oil pumps arnt really required unless you bearing clearances are high, id say somewhere around .003" but overall its not going to hurt anytthing, just for future reference
Formerly Blownalcoholboy 1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi) Best ET 1/4: 8.35 @ 170mph (275 drag radial) Best ET 1/8: 5.44 @ 132mph (275 drag radial) Best 60': 1.31 on the back tires (275 drag radial) AF User Rules/Guidelines http://www.automotiveforums.com/vbul...uidelines.html |
Re: my parts list
you didnt say anything about a cam. you only have 1.5 rockers listed on there and you probably wont be getting the most out of those heads unless you go with a really wild hydraulic roller cam. I think you might want atleast 1.6 (maybe 1.7 depending on the cam) to get the most out of those head, cuz they can take a lot of lift.
*EDIT whoops, isee the cam now. what are the specs?
90 Camaro RS V6 - swapped to V8 -350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft ESTIMATED 360-420 hp 380-430lb/ft torque
Re: my parts list
2,200-6,400 RPMIntake Duration at 050 inch Lift:233Exhaust Duration at 050 inch Lift:241Duration at 050 inch Lift:233 int./241 exh.Advertised Intake Duration:276Advertised Exhaust Duration:284Advertised Duration:276 int./284 exh.Intake Valve Lift with Factory Rocker Arm Ratio:0.504 in.Exhaust Valve Lift with Factory Rocker Arm Ratio:0.525 in.
Re: my parts list
hmm.. thats a well thought out list. great choice of parts! theres not much to improve on. what tranny/drivetrain parts will you be using?
and how far along is this? got anything built yet? pics? when you planning on starting it up? that's gonna be a lot to handle in that 68! Nice!
Re: my parts list
parts come in wed through friday. Rotating assembly might be here end of this week or early next week. Getting started ass soon as I can. My goal is to get this done by may 18th for a big car show. I will probably have to upgrage the drivetrain. Right now I have a 700r4 with a shift kit out of a 88 IROC and a 12 bolt rear with 3.42's.
Re: my parts list
upgrade on the trans, it will hold but not for long, especially if you get on the go pedal
Re: my parts list
my goal is to get through this year.
