Old 03-25-2007, 10:33 PM
FGlass FGlass is offline
Which 02 sensor (1.3L)
When a 97 metro 1.3 shows an O2 code, is it the upstream (near manifold) or downstream one (near converter), which is causing the trouble?
Old 03-26-2007, 03:04 PM
spy1309 spy1309 is offline
Re: Which 02 sensor (1.3L)
The upstream one
Old 03-28-2007, 03:12 PM
Thanks,
the exact code said PO 141 "Bank 1 Sensor 2" O2 sensor heater circuit malfunction?
Then there was a 0400 EGR Flow malfunction, but that one was reset and did not reoccur
So is it still the upstream one?
Thanks again
FGlass
Old 03-29-2007, 01:02 AM
hot_sd hot_sd is offline
Sensor 2 is the downstream one(after the catalytic converter). "bank 1 Sensor 2" is the generic interpretation of the OBD2 code. In the case of the Metro bank 1 has no meaning.
Sounds like the heater in the sensor has burned out. You can check it for continuity with a multimeter.
Bit suprised about the EGR code - I have a 2000 1.3L and these do not have EGR. Maybe they were designed out in the later models.
BTW the code is actually P0141 - not PO141 (zero next to the P)
