Old 03-25-2007, 10:28 PM
toolhead toolhead is offline
Send a message via AIM to toolhead
idle question
Every time i start my car. weather its cold or warmed up the idle jumps around and feels like it wants to stall. then when i drive it down the street and stop it idles fine. is there a way to adjust the idle? or is it suppose to be like that?
Old 03-25-2007, 10:39 PM
G_Bo32 G_Bo32 is offline
Re: idle question
My 3000GT Does the same thing.. Kinda curious about it myself
Old 03-25-2007, 11:01 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: idle question
IAC probly needs cleaned.
Old 03-25-2007, 11:02 PM
Re: idle question
Unabreviated please
Old 03-25-2007, 11:05 PM
Stealthee's Avatar
Re: idle question
idle air controller. Search on Stealth316.com and it has good directions for taking it out and cleaning it.
Old 03-26-2007, 12:46 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: idle question
also search this forum, as this question has been asked several times before.
there is a motor on the throttle body that lets air bypass the throttle body to control the idle under different conditions. this motor is called the IAC aka ISC (idle air controller/idle stepper controller).
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 03-26-2007, 03:33 AM
Re: idle question
What if your engine idles at high revs.. (2.5k) roughly.
Old 03-26-2007, 07:39 AM
Stealthee's Avatar
Re: idle question
Still could be IAC issue.
Old 03-26-2007, 06:49 PM
Linebckr49's Avatar
Re: idle question
could be a LOT of things, but IAC is the main thing. as i said, do a search and you'll find out what else it could be.
93 3000GT base
Old 03-26-2007, 11:15 PM
Re: idle question
What's the normal rpm's 3kgt's idle at?
Old 03-27-2007, 12:16 AM
Igovert500's Avatar
blue + red light magnet
Re: idle question
700
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
