Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 03-25-2007, 09:27 PM
SwiftThunder's Avatar
SwiftThunder SwiftThunder is offline
Question ABS Light Help!
My dad and I just recently got a 96 explorer xlt 4x4 and the abs light wont turn off. Are there any suggestions for repair. I know there are quite a few sensors but still don't know where to start Please help me trouble shoot.
Old 03-25-2007, 09:48 PM
skibo1 skibo1 is offline
Re: ABS Light Help!
the most common culprit on explorers is the rear spd sensor mounted on top of the diff housing. usually a code c1230 or something close to it saying rear spd snsr fault. try to get the codes from auto zone or somebody with a scan tool with abs capabilities
Old 03-31-2007, 05:24 PM
Re: ABS Light Help!
i know the rear end has a sensor on it and it was unplugged last i checked , i plugged it back in and the light is still on...and the obd II deals with abs also?
Old 03-31-2007, 07:13 PM
Re: ABS Light Help!
96 is borderline on it being obd II controlled, i just checked fords website and it says it is controlled in the dlc under the dash. do you know if it is 2 wheel abs or 4 wheel? either way i still say the rear spd sensor is the likely problem. but see if you can get the code pulled first before buying anything, it should be c1230 or something simular
Old 04-22-2007, 11:43 PM
Re: ABS Light Help!
Ok so being I am working with a similar problem on my ranger I have a question to add. Besides the sensor on the rear end are there any anywhere else? It is a 4x4 with a 4.0L engine.
Old 04-23-2007, 09:19 PM
Re: ABS Light Help!
No bites.. does no one else on af have this problem with the abs light?
Old 04-24-2007, 01:10 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: ABS Light Help!
If your Ranger has 4 wheel ABS, you will have a wheel speed sensor for each front wheel as well.
-Rod
Old 04-24-2007, 10:34 PM
Re: ABS Light Help!
Sorry I wasnt asking about my ranger in this forum i was just saying that im working with the same problem on it. I was asking if there were sensors anywhere else on the explorer I found one on the rear diff. but it is a 4x4 4.0L 1996. Anywhere else to check ?
Old 04-25-2007, 12:40 PM
shorod's Avatar
SHO No Mo
Re: ABS Light Help!
The same would apply to your Explorer, if it's 4WABS, you will have one sensor for each front wheel.
-Rod
