Old 03-25-2007, 09:21 PM
X2Xtreme360 X2Xtreme360 is offline
tiny rust spot
I've got a tiny spot of rust on the passenger rear quater panel (which sucks) and I don't wan't it to spread. The previous owner had what looked to be like silicone covering it up, which seemed to do the trick of stopping the spread but some of it came off, exposing a small spot of rust. What's the best way to contain the spread without having to cut out the metal and replace it with new metal? I was just thinking about re-applying the silicone but I wasn't sure if that was the best route.
Current mods:
Cold air intake
Magnecor 8.5mm competition wires
NGK copper spark plugs
Polished Plenum
KillerGlass radiator hose
Old 03-26-2007, 03:55 AM
AutostradaVR4 AutostradaVR4 is offline
Re: tiny rust spot
the only sure way to stop it is to take it down to bare metal. Hopefully its in a fairly inconspicuous spot.
I had rust on the body welds right behind the front wheels where you would usa a jack. After a little work with the wire wheel i just threw on some primer and some heavy duty epoxy paint and it seems good to go. Of course, if its in the middle of a body panel, youll wanna be more delicate...lol.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 03-26-2007, 08:14 AM
Re: tiny rust spot
Yea it's right where the rear bumper meets the rear quater panel right above the wheel well.
Current mods:
Cold air intake
Polished Plenum
Old 03-26-2007, 02:25 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: tiny rust spot
Your best bet is to sand it down to the bare metal removing all the rust. Then you will want to repaint the area and clear coat it.
