thermostat
On the 2.8 mpfi, what all do you have to remove to get to the damn thermostat? I can't see it but i don't want to tear the whole top of the motor apart looking for it.
2012 Ford Fusion SE 3.0 V6 -SOLD- 1992 Lexus LS400 4.0L V8 -SOLD-1989 Firebird 2.8l V6 Red and White w/flames. Stock. Daily Driver.
Re: thermostat
Should just be under the water neck...follow your radiator hose.
![]() -2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*- |
Re: thermostat
its the aluminum piece connected to the top motor. be careful w. the bolt, i broke a bolt on it.. had to drill it out.. real crappy. soak that thing with WD-40 or something real good.
Car: ![]() 1997 M6 SS Camaro [ white ] 285's in the back all else = STOCK.
Re: thermostat
i'm pretty sure the 2.8 is just like the 3.1 I used to have. If i remember correctly i had to remove the intake ducting, take off the top of the intake plenum (i think it was 8 bolts around the perimeter) and that involved removing a bracket (dont remember what it was for). and then you can access the thermostat housing right below it.
not as easy as a bigger v8 engine.
90 Camaro RS V6 - swapped to V8 -350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft ESTIMATED 360-420 hp 380-430lb/ft torque
Re: thermostat
bracket is for A/C housing. Found out the stat wasn't the problem after all, so i'm saving myself the headache and not messing with the fuel injection system. I just needed new hoses. Changed they belt while i was at it.
