Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-25-2007, 06:58 PM
DSMNerd6889 DSMNerd6889 is offline
Evap removal questions
When removing your evap system, can you unplug the egr, fuel and evap solenoids from the wiring harness, or do you have to leave them plugged in to keep from getting CELs? Thanks!
1990 GSX
PTE SC6152e, tubular manifold, FIC 650's, wiseco/eagle internals, dsmlink, TRE tranny, Apexi dp and cat-back, Apexi EGT and Boost Gauges and Turbo Timer, Megan Racing FPR, Walboro 255 Pump and much more to come.
Old 03-25-2007, 11:11 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Evap removal questions
If you unhook them they are gonna throw a CEL no matter what... UNLESS, you have DSMLink to disable them... Possibly could do it with a datalogger/code reader too...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-26-2007, 08:54 AM
So you're saying I can't unhook the vacuum lines from the evap system without throwing a CEL?
1990 GSX
Old 03-26-2007, 09:59 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Well, I dont have any of that shit and I never threw a CEL .
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-26-2007, 10:49 AM
Well you certainly don't wanna have a vacuum leak from unhooking just those lines... I thought you were talking about the wiring harness plugs to the EGR stuff...
If your gonna take em out then I would just take them all out compeltely and just let the wiring harness plugs hang or whatever you wanna do with them. Get rid of any vacuum lines that you don't need so you have less of a chance for any vacuum leaks. If you get a CEL then you can try to clear the code like I suggested or you could always resort to pulling out the bulb for it like some people do. lol
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 03-28-2007, 12:06 AM
kjewer1 kjewer1 is offline
AF - Advisor
I don't believe the DSMs had any feedback on the EVAP system, so you should be able to remove that. The EGR is monitored on OBD2 cars though, via the MDP sensor. There are ways to trick that sensor into thinking the egr works. The ECU should not care that the solenoids are plugged in or disconnected however, as far as I know.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-28-2007, 12:50 AM
Freakin' Sweet! I haven't seen Kevin post in a while, I feel honored! I went ahead and unhooked the solenoids, but won't be able to fire it up for a while, so I'll just make sure to keep them handy. Thanks for all the help guys.
1990 GSX
