OBD2 CODE PO610 need help on this
1997 PLYMOUTH VOYAGER 3.3 125,000 MILES can some 1 help me out on this code po601 internal conrtol module memory check sum error.... how can i correct this i cleared this but it came back with the engine check light
van runs like new no problems engine smooth tranny smooth thanks CODE PO 601 bobby PS JUST CHANGED BATTERY Last edited by BOBBYVEE007; 03-25-2007 at 10:06 PM. |
Re: OBD2 CODE PO610 need help on this
P0601....Internal Control Module Memory Check Sum Error
Don't see this one very often on the forum. According to numerous sources, it's pretty cut and dried. The Powertrain Control Module (PCM) has an internal failure and needs to be replaced.
If you haven't yet you could try disconnecting the battery a couple minutes and watch for the light to come back on. If it does you need a new PCM.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
thanks ill try that...... i see a guy selling them on e bay and he sets it up with your vin# do u have to have the vin set up with this pcm i guess you would if you need to go to state inspection im in NY because if you get 1 from a junk yard it wont be set up ...the car runs perfect
also where would the pcm be located on this car Thanks again |
If the car is running perfect, and you just changed the battery, maybe the module it good, it's a computer, and computer modules sometime "hiccup". I would disconnect the battery too and reset the codes. Otherwise, maybe you just have a dirty connection going to the thing. Maybe when you changed the battery you somehow erased the ROM in the thing, and it lost your VIN. Also, removing the bulb from the dash will put out the "check engine" light. Maybe a piece of black electrical tape?....
ok i disconnected the battery for 1 hr the service engine soon came back on after 20 mins of driving which brings back the p0601 on my scanner i could get a new pcm for 240.00 and this 1 come pre programed for you car so i would not have to go to the dealer.....i brought it to my friends shop he told me to not worry about it the car is running good the older pcm 96 97 can come pre programed still would like any info on this code
thanks |
I have to agree with your friend, it still runs good, why sweat the light? Another thing is if you replace the PCM, what's to say you won't get the same problem? Just pull out the bulb.
I don't know about where you are,but here if the light is on you fail the emissions test
i have a buddy just gave me the sticker im good for a year
